Help i've blown my currie motor
Re: Help i've blown my currie motor
Postby knoxie » Sat Jun 23, 2012 1:18 pm
yes this sounds like hall sensors for sure, yes you can check the hall sensors, test between the black wire which is the ground wire, so put your black test lead on there, set your meter to DC volts, spin the motor and test between the yellow, green and blue wires you should see pulses up to 5V from each one, if you dont then one of the hall sensors might have failed, it can also be the connection to the hall sensors so check them as well.
Electric KMX 72V Lipo, USPD drive unit. BMX 72V, Puma BMC,
Raleigh 26 inch MTB Puma 50V Turnigy 25C Lipo 10AH, Trek MTB, X5 48V NIMH. Electric BMX
http://tinyurl.com/4vrmc8 http://tinyurl.com/3umm4n
knoxie
Postby okmate » Tue Jun 26, 2012 9:58 am
knoxie wrote:yes this sounds like hall sensors for sure, yes you can check the hall sensors, test between the black wire which is the ground wire, so put your black test lead on there, set your meter to DC volts, spin the motor and test between the yellow, green and blue wires you should see pulses up to 5V from each one, if you dont then one of the hall sensors might have failed, it can also be the connection to the hall sensors so check them as well.
thanks knoxie just checked that mate and the yellow green and blue show 2.5v when spinning not five ?
so if we say the hall sensor has gone is it time to chuck it ?
okmate
1 W
1 W
Postby knoxie » Tue Jun 26, 2012 2:45 pm
no that doesnt look like halls then, check the connections from the hall sensors to the controller, red and black should be 5V and the others should pulse when you power the wheel.
knoxie
Postby okmate » Wed Jun 27, 2012 8:37 am
knoxie wrote:no that doesnt look like halls then, check the connections from the hall sensors to the controller, red and black should be 5V and the others should pulse when you power the wheel.
ok so put my tester on red and black thats no probs when you say the others should pulse how do i test this ?
okmate
1 W
1 W
Postby okmate » Wed Jun 27, 2012 3:01 pm
does anyone no where i can source some hall sensors from
prefer ebay if possible
okmate
1 W
1 W
Postby JoramsWeapon » Wed Jun 27, 2012 3:53 pm
Look for honeywell hall sensors at digikey or jameco
JoramsWeapon
Postby rkosiorek » Thu Jun 28, 2012 11:27 am
popular choice would be the SS41 family of sensors. the ss41 will work with any voltage up to 24V.
digikey, jameco, mouser and RS Components all carry them.
rick
DISCLAIMER:
We will not be responsible for damage to equipment, your ego, blown parts, county wide power outages, spontaneously generated mini (or larger) black holes, planetary disruptions, or personal injury that may result from the use of this material.
- Samuel M. Goldwasser -
rkosiorek
Postby okmate » Wed Jul 04, 2012 11:20 pm
OK guys no need for a hall sensor i found the reason 'it was a short phase wire that was not making a good connection.
all s well again i have been to work back and fourth twice now but think its time to tweak the controller with the usb lead and pc.
the battery's are just not powerful enough to run it at the speed it is set at maybe you can help me with the parameters ?
I have also tried a no load speed test with a meter on amps and it reaches around 5amp
i'm also looking at upgrading my lead acid battery's for somethink more suitable litium lifepoe maybe you can help with that to :D
okmate
1 W
1 W
Postby okmate » Thu Jul 05, 2012 11:56 am
Went to work again on the bike today and pushed it a little more the hill was very little to be perfectly honest but could smell something i jumped off and touched the controller that was warm phase wires were cold but the motor was warmer on the out side with a small amount of smoke coming out any way i left it all day 'but when i finished work it was running very slow got it home and stripped it off the bike 'the evidence was clear it absolutely stunk the phase wires of the stator are well and truly coput heres a few picture so looks like its back to the drawing board 'new hub motor first but maybe i can get a motor similar to the one i have that will bolt right on to the gearing ?
okmate
1 W
1 W
Postby JoramsWeapon » Fri Sep 07, 2012 2:33 pm
Can you put up a few closeup pictures of how the torque plate and hoseclamps go together on the USPD kit? I have a bazillion parts here that came with this kit and I'm certain a good number of them are superfluous...a pic of yours would help.
JoramsWeapon
Postby okmate » Mon Dec 10, 2012 3:43 pm
Hi chaps i'm really interested to find out how these 3 phase motors work how does 24v dc convert to the 3 phase has anyone got any schematics ?
okmate
1 W
1 W
Postby fechter » Mon Dec 10, 2012 4:08 pm
I don't think anybody has the schematic for that motor. Since the controller is potted in epoxy it's hard to reverse engineer. There are schematics of similar controllers around the forum.
Basically, the DC comes in and gets switched by a bank of FETs. Hall effect sensors on the motor tell the controller when to switch so that the magnetic attraction is always in the same direction.
fechter
Postby okmate » Mon Dec 10, 2012 4:12 pm
fechter wrote:I don't think anybody has the schematic for that motor. Since the controller is potted in epoxy it's hard to reverse engineer. There are schematics of similar controllers around the forum.
thanks is is really a 3 phase motor ?
okmate
1 W
1 W
Postby fechter » Wed Dec 12, 2012 8:57 pm
Yes. The controller is really an inverter that converts dc to 3 phase ac.
fechter
PreviousNext
Return to E-Bike Technical
Who is online
Users browsing this forum: sbike and 9 guests
