Can my hub motor and battery handle this?
Postby zooz » Sun May 20, 2012 7:01 pm
Hi people,
I have a kit from BMSBattery - http://www.bmsbattery.com/ebike-kits/34 ... e-kit.html . It is 36V 350W Bafang BPM front drive hub motor with 450W KU93 controller and a 36V11Ah LiFePO4 battery pack - http://www.bmsbattery.com/36v/326-24v-l ... -pack.html .
So I am just wondering if I could replace my 450W controller with a 500W KU123 controller from BMSBattery? Will my battery be still able to coupe with the load? And will my motor not explode due to increased power?
Thanks in advance!
- zooz
zooz
1 W
1 W
Re: Can my hub motor and battery handle this?
Postby tony67 » Sun May 20, 2012 7:42 pm
It will work fine but don't waste your money, you wont even notice the difference. Im not sure what current those controllers actually draw but the sums say 450w draws 12.5 amps and 500w draws 13.8 amps (@36v). If those currents burn out your motor it is better off in the bin.
If your after speed, increase your voltage. If your after acceleration, increase your amps. Have a root around on here and see what the motor will take in terms of watts, 800-1000 should be do-able. Then get a controller that will give you that.
If you keep everything as is and change the controller, a new 25 amp controller @ 36v will give you 900 watts. Research what the motor will take I'm just guessing @ 800-1000 watts based on other small geared motors.
tony67
Postby DCMotorworks » Sun May 20, 2012 8:11 pm
Agreed. the max discharge rate of your battery is listed at 20 amps so about 750 watts is your theoretical limit.
be aware of the potential for catastrophic front fork drop out failure at higher power levels. The numbers are somewhat debatable but general advice seems to be that front hub motors over 500 watts require steel non suspension forks w/ adequate torque arms installed to be safe.
DC
DCMotorworks
1 W
1 W
Postby zooz » Mon May 21, 2012 3:45 pm
Great. Thanks for your answers.
zooz
1 W
1 W
Postby Drunkskunk » Mon May 21, 2012 4:43 pm
Generaly those "1000" watt controllers are set at 22 amps, such as the Inferon controllers (48V X 22A = 1056W) That 22 amps would eat your poor battery alive. That battery is only rated for 10 amps continous, 20 amp burst.
The motor could probably take it. I have a similar motor, and wouldn't fear running it to 1000 watts on occasion.
A 12 FET controller would be overkill. 6 FETs could handle far more power than that motor would survive
Drunkskunk
Postby d8veh » Tue May 22, 2012 4:03 am
You cannot use the KU123 controller with that battery. As soon as you hit full throttle, you're battery will cut-out (assuming it has a decent BMS). The 500w rating is a nominal rating for continuous power, but it can draw more than 1500w from the battery at full throttle. They're set to 30amps max. You're also pushing it a bit with your KU93 controller. Mine draws about 25amps, which is too much for a 12aH LiFePO4. It'll work, but it'll wear out your battery quickly aand then you'll start getting cut-outs at full throttle. If I were you, I'd get a wattmeter so that you can file the shunt in the controller to limit it to about 20amps, or get a Speedict or Cycle Analyst that can do it by software.
All my present bikes that I built can be seen here: http://www.pedelecs.co.uk/forum/members/d8veh.html
d8veh
Postby d8veh » Tue May 22, 2012 4:13 am
Just noticed that it's a front BPM motor. I've fitted three of those to front forks and they're still going strong after about a year with no problems; however, it isn't always easy - as others have found out. If you could post a picture of your drop-outs or forks, we can advise you on how to do it successfully. From my experience the KU93 is a perfect match for the front BPM. What code number is written on yours. If it'sa code 15 you might find it a bit slow at 36v.
d8veh
Postby zooz » Thu May 24, 2012 7:02 pm
d8veh wrote:Just noticed that it's a front BPM motor. I've fitted three of those to front forks and they're still going strong after about a year with no problems; however, it isn't always easy - as others have found out. If you could post a picture of your drop-outs or forks, we can advise you on how to do it successfully. From my experience the KU93 is a perfect match for the front BPM. What code number is written on yours. If it'sa code 15 you might find it a bit slow at 36v.
I will post some pictures as soon as I get a chance. I installed a torque arm as well as some additional washers, seems to be holding up pretty well. I have done about 200 miles in London already, no problem.
It is a code 13 front BPM motor. I am pretty heavy rider, so it is kinda slow anyway :-), but pushes me up the hills pretty good.
Thanks.
zooz
1 W
1 W
Postby cal3thousand » Thu May 24, 2012 7:15 pm
Wouldn't it be better and more cost effective to just put some solder on the shunt?
#1: Diamondback Menona 700c (Commuter)
M/C: e-BikeKit geared rear w/BB7 with 12FET 40A Infineon ebikes.ca
GM 48V LiFePO4 10Ah racked; moving to 12S Turnigy 10Ah framed
+ Speedict, XC30TK disc, Alex Adventurer 700c Disc, Tektro 180mm hyd. with 42mm Kenda Urban
#2: Norco VPS Six DH (Fun) WIP
M/C: Clyte HT3525 (Thanks Meth!!!) http://Methtek.com with Lyen 18FET 24S Regen
Battery: 24S Turnigy 10Ah frame (ABS)
#3: Wifey Bike, Giant eSuede fully customized WIP
cal3thousand
Postby chvidgov.bc.ca » Thu May 24, 2012 8:50 pm
I am able to pull over 30 amps from my KU123 controller. That is overkill for a smaller 11 Ahr battery, unless the C rate is around 3C continuous rating, like a Headway pack.
CatrikeRoad Rear9C 2805 KU123Sensorless CA
DevinciVancouver Front9C Disk
Rebike 20"R/16"F Bent C404 Front 48V 20A Crystalyte Pedal First
CCM 26" Cruiser Nexus 7 C406Front 48V 35Amp Crystalyte Start Imm
Sun EZSport CX 26R/20F LWBent C405 Front 48V 35Amp Crystalyte Start Imm
Giant Revive DX 20" Nexus 7 RearSusp with 9C Front 48V KU123
Actionbent T1 trike with Rear9C2806 KU123Sensorless CA
Vision R40 Recum USS SWB EZEE
CannondaleHooligan Cute100 48VHead 60T ring KU63
chvidgov.bc.ca
Return to E-Bike Technical
Who is online
Users browsing this forum: Dauntless, launchpad, Neomanderx3 and 15 guests
