Regen with lyen controller
Re: Regen with lyen controller
Postby Ypedal » Thu Jul 05, 2012 9:01 am
I need to go read that link above.. but just a quick bit of into from my personal KMX experience..
Regen only works for me by shorting the yellow/black ( ebrake ) wires.. as long as the white wire is hooked up.. if i disconnect the white wire, regen does not work.
I run 24S lipo. 100v, below 10kph i get no regen.
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Postby Raphael » Thu Jul 05, 2012 9:35 am
I've read through the thread, nothing new in there to solve the problem
Yes Ypedal, that's what I experienced too, connect the white wire to enable regen generally and then make a switch somehow to on/off the regen on black/yellow. But Lyen told me it's possible to enable throttle-regen - and I can't get it to work so far...
Otherwise the controllers are great and Edward Lyen was always super-helpful...
Raphael
Postby Ypedal » Thu Jul 05, 2012 9:38 am
I would not want throttle regen enabled anyways.. i like to pulse and glide, letting off the throttle compeltely and coasting to stops when possible, and when i do let get of the throttle i dont want the regen to kick in un-expectedly..i want to pull the lever when i want it.
You can use a simple magnet with double sided tape on the brake lever, a bike wheel speed sensor as an on/off switch in proximity to the magnet and whamp.. ebrake on your own lever.. ( thanks Rick ! )
Ypedal
Postby Jeremy Harris » Thu Jul 05, 2012 11:17 am
Raphael wrote:I've read through the thread, nothing new in there to solve the problem
I take it this is the problem you're referring too:
Raphael wrote:1. possibility: enable throttle regen. However, I am not able to make that work. I configured it with Lyens software (slip mode = true) but it doesn't work at all. It only brakes when I short the brake-wires, I would have expected it regens when I zero the throttle?
If so, then to make throttle regen work (which is really throttle off regen for these controllers) have you followed the instructions in Will Newton's paper in that thread? Specifically these instructions:
"16. EBSLimVoltage- This is the maximum regeneration voltage. !! Dependent on the R12 voltage divider !!The same rules apply for the REGEN voltages as LVC voltages shown above. 55V, 60V, 75V correspond to 66V, 72V, and 90V"
"26. SlipChargeMode- The Slip Current Charge Mode feature is either "ON or OFF" and allows regen from the throttle. Throttling back when cruising will regen the Direct Drive hub motor and slow it down to about 15% of full speed. The eBrake regen and the Throttle regen act independent of each other. I set the Throttle regen to "OFF" by default (I like to coast freely when throttled back). Values are 0: UP 15 Mark (throttle regen) and 1:Only Fake Indicate (no throttle regen)"
"27. EBS Level- This sets the strength of the regeneration. A higher number is stronger.When the eBrakes are applied the Direct Drive hub motor will slow down to a complete stop. values are 0: (low), 1: (med.), and 2: (high) Setting 2: has been recommended for 26" wheels if you are using regen and the other numbers for smaller wheels."
In addition, you have to follow this instruction to jumper the regen link:
"Jumping (or connecting a switch) from BK to GND activates the Regen braking feature."
The most common reason for regen not working is either the regen link not being there, the programming not being set or the battery pack voltage being over the limit.
FWIW I agree with Ypedal, throttle off regen feels wrong to me, it was like engine braking on a car and just felt a bit odd on a bike.
Jeremy Harris
Postby John in CR » Thu Jul 05, 2012 6:51 pm
I use Slip Charge = 0: Ture and regen comes on when I let off the throttle. It doesn't even have to be throttle 0. It works great as long as the regen force is fairly mild like it is with speed wind motors. Twist to go and let off to slow down can be liberating in its simplicity. I've gone entire rides never touching the brake.
Ask Lyen if that doesn't work for you.
John in CR
Postby wineboyrider » Thu Jul 05, 2012 6:55 pm
Ypedal wrote:I need to go read that link above.. but just a quick bit of into from my personal KMX experience..
24s with the stock lyen 9fetter? :lol: 8)
wineboyrider
Postby zooz » Sun Jul 15, 2012 7:07 am
Recently I installed a new Lyen 12 FET Mark II enhanced controller. What I did to get regen to work on 18s2p RC Lipo running HS3540:
1. Make sure white wires on the controller are connected (this enabled Regen function)
2. Make sure Regen is enabled and set to 75V software wise
3. Install a push-to-make button near the left brake lever
Well, at least that's what I did and it works very well. That's the first braking regen experience to me, so I will tell you what I observed after a few rides. Few things to note, that when my battery pack is hot off charger at 75V, regen does not work as expected, because pack is full and secondly it's already at 75V.
Let's assume your battery pack is at 70V with some capacity already used and EBS Level is set to 2. If so, then regen should definitely work. The faster you're moving the more amps you're going to get out of braking. Usually I manage to get around 13-15 amps for a few seconds and then it drops down as I am stopping.
From my experience braking regen does not stop you to a dead stop, it kind of cuts off when you're moving at 5-10km/h, so then you have to use your normal brakes or even before, because at slow speeds there is not much braking happening out of regen.
Give me a shout if you want to see some pictures of my push-to-make button hack.
zooz
1 W
1 W
Return to E-Bike Technical
Who is online
Users browsing this forum: wesnewell and 6 guests
