dabeindan
Greeting everyone, just received my kit from BMS, have it spread all over my living room trying to make sense of wiring, connectors, etc. Looks like I am missing some small wiring pieces so hoping to get some confirmations here before I fry the components.
The KU93 controller power wiring has 3 wires, thick red (+), thick black (-), thin red (switch). View attachment 1
The battery end has only two poles, marked "+" and "-".
The key lock is just a mechanical lock for securing the battery, does not have an electrical switch. There is a switch on the other end of the battery (on/off), but no exposed wiring..
---------------------Below is their descriptions of the controller wiring-------------------
Power wire (3P Plug)
Red: Power Anodic; Black: Cathodal; Red(small Connect Red to Red(small wire): power on.
Disconnect Red to Red(small wire): power off.
So the question is, do I:
1) Connect controller thick red wire to battery "+", and then thick black to "-" and leave the thin red disconnected?
2) Same as 1 but also connect the controller thin red to the battery "+"?
3) Or do I have this all wrong.
my very first attempt, sorry for the newbie question. thanks in advance for all the help.
Laurent.
Laurent.
