shinyballs
- Tested continuity between phases
- Checked phases and hall wires for shorts
- Checked for resistance between the phase wires and the motor axle
- controller, throttle and hall sensors are fine
- wiring combination between motor and controller
Did the tests above, I also checked the wiring/connectors and don't see any damage. I'm using it with a kelly kbs and CON121 in sensorless/sensored mode.
