Wurly
I bought a spare charger from BMS battery for my 48V ping battery. It is a small black alloy cased one that i intend to use if my other charger goes wrong.
When i selected the charge voltage it recommended 3.55v per cell. So my charger output should be 56.8V for 16cells. (It is actually 56.7V)
Now i realise that i should have requested a slightly higher voltage as the signalab BMS leds illuminate at >3.6V. Therefore i don't have any visual way of seeing if the battery is fully charged or not.
So....is there a way of increasing the volts to say 3.62V per cell or about 58V? I took the end cover off and can see 4 multiturn pots. Which one do i need to adjust?
