ZapPat wrote:And wouldn't some amount of RC filtering using small caps be necessary in this type of setup? I would think that PWM switching noise might be a problem without them, no?
mikereidis wrote:My XLyte 72v, 20a controller is working fine at 84v, but I'm getting tired of pedal first on this heavy recumbent.
John in CR wrote:I asked about 60° and 120° phasing and was told the controller is supposed to sense which the motor is and send the correct signal accordingly.
John
ZapPat wrote:Anyone know where I could get torque arms - which I think is what I need right? I live in the middle of nowhere, so an internet source for these would be great, and it being in canada would be a bonus for me. Other DIY solutions for this problem are also welcome!
ZapPat wrote:Well I got the new infinion working well finally! In fact it works so well compared to my old controller that my motor twisted itself partway off the bike! It was throwing gravel bewind me when I hit the accelerator, something that just barely happened with my old moded golden motor controller (which was a 36V/20A moded to 48V/34A). As soon as I figure out how to secure this beast to my bike frame I will have a great time. Anyone know where I could get torque arms - which I think is what I need right? I live in the middle of nowhere, so an internet source for these would be great, and it being in canada would be a bonus for me. Other DIY solutions for this problem are also welcome!
There is still a small glitch in my infinion that happens only at the very lowest possible throttle setting, but is easily avoided by going up a bit higher right away. This is what was confusing me during my initial hall and phase wire combo testing, and also that I was using a 72 volt controller on 48V, so had to bypass some of the power resistors. The LVC is easily changed with a potentiometer (provided!).
Thanks,
Pat
John in CR wrote:ZapPat wrote:Anyone know where I could get torque arms - which I think is what I need right? I live in the middle of nowhere, so an internet source for these would be great, and it being in canada would be a bonus for me. Other DIY solutions for this problem are also welcome!
Pat,
Look in your tool box. The quickest DIY solution is that open ended wrench with a 10 on it. The idea is to just prevent the axle from turning. The nuts hold the axle on. That will give you security while you come up with something better, like welding two 10mm open ended wrenches together so it slides over the axle and can't turn or come off without removing the torque arm.
John
Thanks,
Pat
Pat,
John
geoff57 wrote:make sure its not a cheap wrench they are the ones that will do the dammage
geoff57 wrote:ZapPat wrote:[...]
hi pat elaborate on the glitch I'm doing tests on the 72v 45a infineon at the moment with puma I run at both 48v and 72v depending on what I want speed or distance.
I'd like to know about the glitch at low throttle so if I get the same I know it has been found before, we still have to get rid of it though.
ZapPat wrote: Almost as though it might have to do with some one-time initialisation code not always doing the same thing.
The7 wrote:ZapPat wrote: Almost as though it might have to do with some one-time initialisation code not always doing the same thing.
Seems this could be the good and the bad!
fechter wrote:Torque arms? I'd recommend these: http://endless-sphere.com/forums/viewtopic.php?f=9&t=5788
Users browsing this forum: GSteg and 12 guests
