Minas
Hey There!
So I'm assembling my first E-Bike which is basically a Vitus Gravir dual susp frame with all of the componentry of my "07 Giant XTC
(it uses Avid Juicy Hydro brakes with 160mm rotors)
I am using a Crystalyte H4040 motor and the first thing I noticed was when I mounted up the rotor the hydraulic calliper would hit on the motor,
so I decided I would use a smaller rotor behind it to space it out, enough that it would clear ( literally 1mm clearance )
So I thought I would be sweet until I went to mount up the calliper and bam it was out by like another 10mm...
I spaced the calliper across with a few washers and as ghetto as it looks it actually works quiet well, with little to no resistance.
HOWEVER... I don't like it like that, It scares me.
Has anyone else come across this issue and if so how did you fix it?
Minas
Minas
