Hi,
I just receved a couple of these controllers as I wanted to test them with the new S-LCD3 display.
Two things:
1. Speed sensor: It appears to have an input for a hall-sensor as the connector has 3 pins rather than 2 (for a normal reed switch) Does anybody know, if there's a way to connect a normal reed-switch "speed sensor"?
I have a hall-sensor built into my Xofo rear motor, but it only engages when the motor is spinning and I cycle often enough without the motor and would like to see, how fast I'm going.
2. Brake sensors: Same thing: it seems to be for a reed sensor brake sensor. I have reed switches mounted on all bikes and would like to connect it.
Thanks guys.
Two things:
Thanks guys.
