ARod1993 said:
While doing a bit of Googling on IGHs I realized that basically all of them have internal freewheels that make it impossible to implement regen, which in this case is a major downside. I don't want to deal with the losses and extra weight of a motorcycle or dirt bike gearbox, but I want to be able to have regen on this build; does anyone know whether it's possible to modify an IGH in a manner that would disable the freewheel without compromising its ability to shift?
I've looked at this in quite some depth for a kind of application (geared unicycles), and both the short answer is generally no. The internal mechanism relies on the internal play from it freewheeling in order to be able to shift, and the freehweeling pawls are integrated an not usually a separate piece that you can simply take out or disable. The Nuvinci CVT hub is tempting, but in that case it relies on forwards torque on the sprocket to compress the friction plates against the transmission balls. With a backwards torque and there is no compression and it simply slips, have a look at the 5th post here:
http://www.unicyclist.com/forums/showthread.php?t=89581
As mentioned in that thread, the Sturney Archer S3X is one of the few bicycle IGH's with reverse torque transmission. But it's only 3 speeds with a 160% range, and people have blown them out with aggressive pedaling, let alone high powered ebike drives. So in your case I don't think it would hold up at all:
http://www.sturmey-archer.com/products/hubs/cid/3/id/47.html
Does anyone know if the multispeed bottom bracket transmission drives like the Pinion are reverse transmitting? There is a lot more torque on the front crank than you have on the rear hub so the gears inside would be built to handle higher torque loads:
http://pinion.eu/en/discover-pinion/pinion-p1-18/
