Xsys
Hello everybody!
I'm having a bit of trouble with my e-bike.
Controller: 12 FET 72-110V Mark II High Voltage Racing LYEN Edition Controller
Motor: Golden Motor Magic Pie 3
So i just finished up building my battery pack (LIPO 24s), was really excited so I connected the halls and phase wires, the throttle and the cycle analyst to the controller.
I followed the color codes from Lyen's website from his controller to the Magic Pie 3 motor.
Phase: Match all the colors.
Hall: Blue-Blue, Green-Yellow, Yellow-Green.
Everything's connected correct, right?
I hooked up the battery to the controller, the cycle analyst lit up and showed the correct voltage. Looks good so far.
I turned the throttle just a little bit, the motor started shaking and made a horrible whining noise. I figured it was the wrong wiring on the halls wires, and so it was. I switched out the hall wires to match, Blue-Blue, Green-Green and Yellow-Yellow.
I tried it again, turned the throttle (slowly) just a little bit for 2-3 seconds. It ran great! No weird noise, everything looked ok on the cycle analyst screen. I used the manual breaks to stop the wheel from spinning. When the wheel stopped, I wanted to try it again. So I turned the throttle (slowly), the Cycle Analyst blacked out and nothing more happened. No response when i turned the throttle.
My first thought was the battery. I opened up my pack, look at everything inside and received good readings from the voltmeter, inc the precharge resistor i built into the pack with a switch.
After checking the battery pack out, I connected it into the controller again, used the precharge resistor(1kohm 10w) to not get a spark, waited about 10 seconds and then connected the main red lead. Giant blue spark and I pissed my pants because i wasn't expecting one. No short or anything, just a standard (giant) spark when the electricity rush into the controller. Why didn't it work now when it worked earlier? I looked at it earlier in the battery pack and it looked like nothing was wrong with it. Anyways, the Cycle Analyst screen went completely green for almost 2 seconds, then blacked out. i tried to turn the throttle, no response.
So I started to use the voltmeter to get readings for the throttle to make sure it was working. Great results, nothing wrong with that. After the throttle I tested the hall sensors on the motor just to make sure nothing was wrong. And nothing was wrong there. Phase wires ok too.
I opened up the controller, I don't really know what to look for in that box, but nothing was burnt so I take that as a good sign...
But something happened, was it the controller? Did I do something wrong? I do not know what to do here. Please help me here...
PS. When the Magic Pie is not connected to anything, it spins really good and freely. As soon as I connect the motor to the controller, it doesn't spin as good, feels like there's more resistance and really lumpy.
Thank you, any help is really, really appreciated.
