bowlofsalad
I am looking for cartridge bearing with contact seals that will do an adequate job of resisting rain and debris entry, as well as prevent low viscosity oil(no pressure behind the fluid) from getting escaping.
http://www.skf.com/group/products/bearings-units-housings/ball-bearings/deep-groove-ball-bearings/single-row-deep-groove-ball-bearings/sealed-bearings/bearings-with-contact-seals/index.html There is a table here that shows various bearing seals and sort of compares them. 2RSL, 2RS and 2RSH all have various degrees of sealing, there are other seals, and surely other seals sold by other companies, there is something of a wide selection and the problem is I have no solid way of knowing what is ideal for doing the job.
I am hopeful someone on this forum is knowledgeable on the subject of sealed cartridge bearings and can shed some light on this subject. What would be adequate for this application?
Thanks with a side of guacamole.
