Greg5972
Hi Gents,
I have an issue I was hoping someone can help me with. I just purchased a 24 fet crystalyte controller from Hi-Powered Cycles. I am using it on my phasor to replace an 18fet 4115 controller from Lyen. Only to underrate it hopefully end up with cooler running temps on the controller. My setup is 24s2p made from 8 8000mah 6s zippy packs. I am running a 4065 motor in 24inch rim. I am also running a Cycle analyst 3. I can seem to get the Ca to run the throttle of the crystalye controller via the Ca connection. As it turns out HP cycles said they have never tried this controller with a Ca 3 only a 2.3 which is surprising in my opinion.... If the throttle connection is wired direct to the controller the controller works fine but I what the Ca to control the throttle as I want to limit the amperage to 45 and for so many other reasons.. This is what it have tried.
1k ohm resistor from negative to green wire of Ca.
Removing green wire from Ca connector and connecting to the throttle input of the controller.
Shorting the throttle input of the controller to the 5 volt signal.
All unsuccessful.
Any input would be appreciated
Thanks!
Greg
All unsuccessful.
Thanks!
Greg
