wojtek
Lyen Mk 2 24 4115 controller, 1000OHM, 3.6k resistor [most likely]. 24s Lipo, programmed with XPD at 82V regen [MAX] , also tried Lyen software at 75V regen. EB312.
When wheel lifted, i can see regen working [CA showing negative A, wheel slowing down] however when i'm riding the trike, pressing regen button only cuts off the power... no regen..
Checked also with 18S [66v nominal] battery setup, same problem.
any suggestions much appreciated, i run out of ideas
thanks!
thanks!
