Hi all,
I just got my first ebike up and going but having a few issues. It is a MAC motor, 12 FET Infineon controller, and a CA v3. I am hoping the issues are all related... or at least 2 of them.
First, the ebrakes. When I use the left brake it will disengage the throttle. Not the case on the right brake. When I have the auto cruise on, the right brake or left brake will not disable the auto cruise from the CA. The only way to disable the auto cruise is to push the green cruise button.
Second, the auto cruise feature on the CA. Intermittently, when the cruise control automatically comes on it will accelerate and keep accelerating until I manually stop it (by pushing the green button). Sometimes though it will not do this and stay at or near the desired speed. I researched this issue on the forum and someone in the past had a similar issue and they recommend that the throttle be replaced. So I did that, but no luck. The problem is still there.
Third, the three speed switch. I have tried to use the switch to limit my speed but the only way that the switch will limit the speed is by selecting to have it limit by mph. I would prefer to limit it by power. Whenever I select the voltage settings the switch does nothing.
If you have any ideas I would really appreciate your help.
Thanks in advance.
Thanks in advance.
