Hi,
Have just put together a BMC V4C hub motor and an Infineon 9 fet, 28 amp controller from Ebikes SF. The hub is surging/cutting out at high amps.
Could be batteries? ( have 2 x 5 amp, 8s zippys in parallel, then same again in series to make 61v)
Could be phase or hall wires ( buzzed all wires and tested halls Ok)
Could be controller? Have tested every static voltage OK.
Could be induction from phase to hall sensor?
Could be CA settings?
Can someone please PM me a copy of a Cycle Analyst V3 .hex file with settings that work? Or is this club CA?
I have received two controllers ( Don't really want to talk about the first one (reversed phases) ) I not sure if I have a fault or the Cycle Analyst needs a massage. I have managed to improve the surging/cutting out a bit with settings ( stuttering moved from 400w to 650W but dragging it up the stairs is wearing a bit thin.)
Cheers
Cheers
