agniusm
Hi. I have decided to try and run sort of kickstarter on ES as the product i am making is more technical for casual folks. This first post is just a glimpse of the product and i will update it as often as i can.
First of, what it is. It is a ignition switch, expensive one, fancy one. Its mostly meant for bikes with box frame: Stealth, Phasor, Qulbix, Chaika, Boggrunner, but could be used by anyone building custom bikes.
It is a true fingerprint ignition system. It can store 200 fingerprints. It controls 2 switches. The first one is your usual ignition and the second one is 3 speed switch, more like 2 speed switch in this case.
How does it work? Pressing latching switch energizes the system, the you scan your finger, red switch LED lights up and your bike is life. You press it again, switch LED changes to green, and now your bike is in limited power mode, scan again and it goes back in full power mode, infinite loop. There are 2 users to enroll. First is Administrator, second is User. Administrator can change power mode when scanning fingerprint and User has limited power profile. Whenever User scans hes fingerprint, switch LED goes into green and limited power engages, scanning second time gives visual indication, red LED blinks twice and goes back into green, limited power. This option is good to have your kids use the bike with limited power.
Here is a prototype:
The finished product will be made out of aluminium, anodized, yet to confirm colors, black for sure. There will be no visible bolts just rounded 40x100x5mm plate with switch and scanner panel:
There will be a gasket to waterproof it from outside and if all goes good plastic cover with connector from inside.
Here is a short vid:
[youtube]PVeeVSsBmec[/youtube]
Needs 12V for power(???).
The enrollment of fingerprints is done via mini USB (Arduino based device).
I am hoping to rise some interest and basically take pre-production orders. As i always say, i am small operator and don't have too much funds to invest.
It will be probably 1 month ordering time an 3 months manufacturing to delivery.
Hope you like it
Hope you like it
