mamcinty said:
My experience with tools is that it usually pays to just buy the "right/best" thing and I know many consider this the "standard".
Can anyone recommend a stand that doesn't cost quite as much but won't be a waste of money? I'm mostly concerned about getting something that is solid enough for a hub motor, which is why I am asking here. I don't mind making a base out of wood for it.
I'm generally of the belief that the novice needs the best quality tool - the Ole Pro can make anything work because experience lets him recognize the difficulties with the tool and compensate with an extra dash of skill.
I was in a similar situation earlier this year and found a stand by Bikehand to be almost identical to the Park unit except for finish - at a much lower cost (see Amazon, etc). Of course, it's also pretty obvious that these stands are designed for 'business throughput' - to minimize setup time, etc. For the occasional home wheel builder, other designs might be less complicated without sacrificing accuracy or utility, but good quality alternative designs did not seem to be available.
Fortunately, before I bought the Bikehand unit, I ran across an on-line wheel building book
"The Professional Guide to Wheelbuilding" that I found quite good - very detailed and thorough. Interestingly, it had detailed plans for what appeared to be a pretty nice stand. The 'book' stand is made of MDF and a few bits of wood. Using materials and tools that I had on hand, I fabbed up my own version, using the critical design elements of the book version - almost free except for some hardware bits (the varnish for the MDF base was actually the most expensive part). I sacrificed the speed of dropout width adjustment for a a slower technique that simplified construction - a couple of minutes of extra setup time is not an issue for me. Lots of ways to do this - this is just an example...
I found the unusual truing guides to be intuitive and easy to use. The clever design sidestepped the more complicated mechanism of the Park unit and is at least as accurate (no long cantilevered arm). I fabbed my versions PDQ from plastic scraps and a $5 cutting board. Dishing is measured from upright-to-rim with a $10 Harbor Freight digital caliper (a pocket rule would work) - again, stuff on hand...
With this stand and a Park TM-1 tension meter, truing has gone without a hitch. The tension meter is pretty important to get the tension right (or at least not terribly wrong). With experience and a good ear, you can pluck your way to good builds, but harkening back to the 'novice' theory - this is money well spent IMHO - particularly if you can offset the cost by cooking up a stand yourself.
- (I actually had photos in hand, etc for posting about this in my build thread, but this thread came along and looks like a good home for a few of them... )
EDIT - Well - I broke down and posted up the Truing Stand details in my build thread as an example of a WheelPro-like DIY stand - here!
