Obiwan007
Edit: So I fixed the 3-speed switch and noted a new symptom; backward rolling resistence (a lot) when the controller is powered up and none when it is powered down. This was definitely not the case before this problem started. I have checked the function of the hall sensor and the mosfets and found them to be functioning properly per the guides on the Grin site. Please help if you can
So my bike has been running perfectly for many months now and I just love it. Build here
http://endless-sphere.com/forums/viewtopic.php?f=2&t=55605
So yesterday I first noticed that the power level felt like I had the 3-speed switch set to level 1 (slowest). And there was no change in the power level in any of the three positions of the switch. I have checked the plug and it has continuity throught the plug. My first thought was that the 3-speed switch had a problem. But then I noted on the CA that when I ran the bike at WOT the battery voltage was sagging from full charge 74v briefly all the way down to 65v. Now I confess that I don't regularly watch for this but that seems like a lot...too much. So, any thoughts on how to proceed? How can I test the 3-speed switch for proper function? What other things might cause these symptoms? Any thoughts from the collected wisdom? BTW my set-up is 18s2p of 8000mAh HK Zippy lipo, running a V2 Cromotor through an 18 fet Lyen controller and a V3 CA. HELP! My baby is sick.
