I made myself a torque arm out of 10mm S235JR steel. Now the arm itself should be bulletproof i'm not sure if my frame will. But i'm not sure about the mount location. On the chain side i can only bolt on a small hole and on the brake side i will bolt it to the IS mount.
My system is:
9C 2805 (With an calculated torque of about 110Nm)
Controller is 100v 45A
72V 13Ah 18650 Pack (200mOhm Ri)
To all experts, can i expect to run without fear of a breaking frame.
Some pictures.
This side only is bolted in the small M5 hole same as on the second picture
Here i will also use 10mm or 3/8" S235JR steel, but bolt it to the IS mount
My system is:
Some pictures.
