The OP did not say he wished to control the acceleration with the throttle. The V3 throttle ramping function effectively limits acceleration.quamau said:CAv3 provides current throttle and power throttle in addition to speed throttle. It's not acceleration (doing literally that would be obviously unfeasible...
As suggested above, you might be best served by examining the V3 Unofficial Guide. In particular, see sections "1.2.6 Throttle Enhancements", "5.2 Closed-Loop Throttle Modes", and "4.8 Adjust Throttle Ramping"brianLEV said:all the throttle i see are potentiometer so it's voltage signal throttle. how does CA3 convert it to current throttle or power throttle?
what are the advantages of current throttle over typical potentiometer voltage signal throttle?
brianLEV said:so the rate of change of voltage in the throttle signal is proportional to the current going into the motor, hence acceleration. to clarify.
brianLEV said:.... how does it know how much acceleration needed to maintain constant speed?
