Domino
Hi,
Please help. i bought a second hand ebike kit which consists of :
Banfang 250w hub motor on 700c
King-meter
Controller: CE:G3M20211-1592-16.
It all looks virtually new with the odometer displaying 330 miles or km? can't recall format.
The speedo unit lights up and even displays speed when the wheel is turned however no drive results from throttle use.
I have carried out some tests as stated in Mathew Slinns Great Build your own Electric bike book. The Controllers capacitors and FETs are ok, the throttle seems to be working however the hub will not power up and I confirmed ( with multi-meter) There is no power across the phase wires when throttle is opened. I have noticed (with controller cover removed) as soon as the system is switched on, at the Dash board (king-meter) there is a small red light on the controller circuit board constantly flashing. What does this indicate? Also there are three modes on the dashboard? I do not have any instructions to go on Any advice please.
King-meter
