MAGICPIE3FOCUSPOWER said:
Hi All! 8)
I am a little bit confused while looking for some circuit breaker.
What is/are the difference(s) between AC and DC circuitbreaker?
Thanks for help!
AC is alternating current and every time it cross the 0 volt when changing polarity this blow the arc that the Dc current like to produce. Normally the design of a DC fuse and breaker are different and more complicated. if you use a 32V max fuse ( found on the 12V car) to cut 100V dc there is a risk of when the fuse blow, the arc that is created continue to live for few second and it make everything to melt around due to the intense heat.. this can cause a fire. this is not a problem with AC because the voltage change and cross zero witch blow the arc 120 times per second.
Dc fuse and breaker have longer gap between the contact and this reduce the arc problem.
you can get some decent quality circuit breaker here for DC up to 150V
some popular are the Airpax of 80V.. but there is also some 150vdc one.
Some have screw and some have already the bullet connector!!
MidNite Solar DC Circuit Breaker MNEPV
http://www.cafr.ebay.ca/itm/8A-10A-...-Breaker-disjoncte-Solar-Charge-/271147082582
Airpax:
http://www.ebay.com/itm/Airpax-LELK1-1REC4R-32969-80-V-DC-BREAKER-80A-/111394715244
Doc
