I have read quite a lot about the new Ezip Trailz factory set controller not being able to handle 36V and have also read that the stock motor can burn up at 36V as well. Therefore, I have come up with a plan to upgrade my new ezip to take 36V... Electricscooterparts.com sells a 36V motor which has the same dimensions as the ezip stock motor so I will order that and order a 36V controller as well. The only tricky thing is I have to figure out how to appropriately wire the new controller based on the diagram given and compare it to how my stock controller is wired. I know the connectors for the wires inside the controller will be different, but all I have to do in that circumstance is cut off some of the new connectors and put on the ones which appropriately match the wiring connectors of my ezip.
I would like to know if anyone has done this. At this point it is only an idea... I have not moved forward with it yet as I do not know how much of an improvement in speed and range it would make.
