Brushed Heinzmann 250w without controller!
waingroo
Hi,
I need some opinions about using a brushed Heinzmann 32v, 250w on direct Lipo source without controller and with a potentiometer throttle instead a hall sensor one.
As I know, these hubs can handle up to 1000W for short times. The battery I will use is a Li-ion 9A, 36V, 316Ah 12C which can result a discharge of ~3000W.
There is the risk to burn the hub or the battery BMS?
I really need hight torque just for secons on short hills.
Bad, bad idea. During start up, the controller limits the current to something reasonable. Without it, the motor will eat all the amps it can get, and fry. During start up, the windings in a motor are essentially a dead short on the battery, with only the resistance of the copper to slow the current down. If your motor has a winding resistance of .001 ohms, then 32 volts / .01 ohms = 3200 amps. That's 102,400 watts trying to go through the motor.
With many batteries, such as Lead acid, their high internal resistance would keep the current from ever getting that high, but Lipo have a very low internal resistance. Likely the battery and motor would both be destroyed. If they didn't blow immediately, there is a real danger that the wires would then begin to burn.
Thanks for warning me! Which can be the best brushed controller who can give best torque for this motor and battery.
P.S. that idea isn't the same with the one used for drill machines?
Brushed controllers are dirt cheap from the electric scooter stores. Just put in electric scooter in google and stand back. I haven't used a brushed controller in years, but they work quite OK with brushed motors like Heinzmann. Just don't go over 36 volts or you will burn the motor out very quickly.
otherDoc
otherDoc
Thank you all for replies and advices!
Now, i'm convenced that I have to use a controller :)
amberwolf said:
Sounds nifty. But the potentiometer is going to be larger and heavier than your battery and motor *combined*.
Look up Luxtrol here on ES
http://www.endless-sphere.com/forums/search.php?keywords=luxtrol&terms=all&author=&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
for my posts to others about a 1kW version (you'll need a bigger one for yours if you really wanna pour 3kW into your 250W motor).
Here's your new controllerless throttle next to the stator from a an MXUS / 9C typical hubmotor (the motor is lighter and smaller than the Luxtrol dimmer!)
file.php
dammit' LOL I thought I can use one from a drill machine
