Actually I bought the throttle from the same place where i got the controller, so they matched easily.I had connected and cross checked everything ,
Battery to Controller,
Precharge resistor,
Kill switch,
Fuse,
Hall sensors to controller,
Phase wires to controller,
Throttle to controller.
After allowing the power supply, i couldn't see any motion in the motor even after putting some throttle. I checked the connections at connectors as well, everything was perfect and power is flowing to the controller but i couldn't see any output from the controller to motor.
I surfed a lot on powering the controller on the forum but couldn't find ,
My controller is some cheap chinese 36v controller with the same silver colored casing outside(what we generally see when we google chinese controller).
1) Will be there any provision to ON/OFF the controller in these type of custom controllers?
2)How to check whether power is flowing from controller to motor?
3)How to check whether controller is powered or not?{ some sort of arrangement we see in KELLY/ Curtis controllers}
4)How to check whether the throttle connections on the controller?
I'm actually new to this field, i just wanna learn things.
Im attaching the picture sent by the dealer showing the connections, but i couldn't make any best use of it.
[ with reference to picture, Im not using
a) Front brake lever with switch
b)Rear brake lever with switch
c)Grip with horn switch
d)Head light
this is the reference picture
This is the controller i have it right now
