teslanv
I made a video to explain the process of determining the shunt resistance (Rshunt) of your controller. This method will work, even if you have modified the shunt to increase your controller's amperage, as it literally measures the actual resistance directly, based on a constant current from an iCharger (Foam Cut mode at 10.0A) and measuring the voltage drop across the shunt, using the CA connector of the Controller.
We do this measurement on every controller we sell, and label the controller for the actual Rshunt value so you can program your CA accurately.
You can do the same for your own controllers with the proper equipment as shown in the video.
[youtube]okpFsoHNE7I[/youtube]
