swbluto wrote:I now have subversion on NetBeans but how do I upload the source code and add a "comment"(Like say "I changed this and that and blah blah")?
Also, how did you get the labels so perfectly aligned? I created new labels for temperature and altitude but they seemed to refuse to align with the other environmental labels. And, I was also wondering, is it possible to put a "new line" in a tool-tip, so the tool-tip could become something like a paragraph or multiple paragraphs?
swbluto wrote:Mine heads towards 100% as you approach the no-load speed and then it crashes to negative infinity at the no-load speed(no motor power output, in other words), whereas ebikes.ca's simulator seems to approach optimal efficiency shortly before the no-load speed and then takes a sharp curve downward. I've heard that the closer you are to the no-load speed, the better the efficiency, so maybe my calculation is more accurate?).
Miles wrote:swbluto wrote:Mine heads towards 100% as you approach the no-load speed and then it crashes to negative infinity at the no-load speed(no motor power output, in other words), whereas ebikes.ca's simulator seems to approach optimal efficiency shortly before the no-load speed and then takes a sharp curve downward. I've heard that the closer you are to the no-load speed, the better the efficiency, so maybe my calculation is more accurate?).
Seems like it's not factoring in the no load torque? The curve should start to turn down at around 10% of no load speed, for BLDC motors.
michaelplogue wrote:Not to bust in on the programing conversation here, but I have a question.
Would it be possible to include chain drive motors plus a front & rear sprocket field so those of us working with non-hub motors could use this great tool? I would think that you would be able to use the same system for both types of motors. You would just put a 1 in both the front and rear sprocket field if you were calculating for a hub motor. You could then also include pre-set data for the most common motors like Etek-r and RT, Perp PMG-130, Lemco's three motors, Some of the D&D and even some of the RC motors that folks are using now.
Just a though.....
tostino wrote:I think I have a solution to the motor stats issue. Lets not hard code them into the program, but instead have it read an external file for motor name, winding resistance, and k. That way users can keep the program up to date with commonly used motors even if this program does end up un-supported in the future.
tostino wrote:Also on a side note, I think there is an issue with the efficency calculation when adding in pedal power. It seems pretty accurate without it in the equation, but with it, everything seems to go out of wack.
tostino wrote:Hrmm. I am not liking the front/rear sprocket to calculate gear ratio at the moment. My motor runs through a jackshaft, than down to the bottom bracket, and through the 21 gears. I am thinking about doing something like I did to calculate "K" down below for the front and rear sprocket to get the gear ratio.
Any objections?
swbluto wrote:Ok, I found out why it doesn't work on macs. It's because macs are stuck back in JDK 1.5(it's latest one currently available for the mac, officially.) which doesn't include the swing library. To download the program with the needed libraries, I've packaged it away in this zip file and it just needs to be extracted so that the folder structure is preserved.
===== Wednesday, 22 October 2008 9:11:45 PM Australia/Sydney =====
Exception in thread "main" java.lang.NoClassDefFoundError: javax/swing/GroupLayout$Group
swbluto wrote:Before I proceed with mac-conversion, could I have a mac user test out the following file? I want to make sure it's right before investing a ton of time. The folder structure must be preserved for it to work correctly, that is if it were to work correctly.
Users browsing this forum: j3tch1u, TreksterJim and 8 guests
