I need to order a steel head tube for a frame build and am getting into a muddle over the available options so could use some advice...
The forks I currently have are a straight 1 1/8" steerer, but I want compatibility with different ones in the future. I understand that adapter headsets are available that let you run a smaller steerer in a larger headtube, but I don't want to end up in a situation needing an uncommon/exotic/expensive headset.
So, what do I need? Straight 1.5" headtube? 1 1/8 to 1.5" tapered headtube? The ones I've seen online seem to be sized in millimetres than explicitly for the steerers they fit. Would those options be 50mm and 44mm to 50mm respectively?
