looking for a 4-way waterproof switch
This is the main place I know to look, but that sounds pretty specialized.
http://www.digikey.com/product-search/en/switches/rotary-switches/1114210?k=switch%204%20way
What about this 'joystik 4way'?
http://www.digikey.com/product-search/en?lang=en&site=us&keywords=switch+4way&x=0&y=0
http://www.digikey.com/product-search/en/switches/navigation-switches-joystick/1114837?k=switch%204%20way
'200$" I hear that!!! What about like a game controller joystick or directional pad? The circuitry and momentary fuction could be upgraded with a pcb for latching on/off fuction.
I'm waiting on these to arrive. They're a bit larger than I wanted, but cheap and should be effective for light loads while easy to seal up with a boot.
http://www.ebay.com/itm/230914853753?_trksid=p2060353.m2749.l2648&ssPageName=STRK%3AMEBIDX%3AIT
i thought of a game controller as well. but making those waterproof is another thing. and i don't have a 3d printer, so i have to plan a lot in advance and can't try out any concepts.
Try Granger.com industrial supply. Will send you a single nut if thats all you want.
Hey izeman, just wondering how you made out? those little switches I linked have come in, and man they are small!
Haven't tested @ pack voltage, and not 100% on how to mount and electrify, but shouldn't be too bad. They measure 10x10mm, and can be mounted thru something with a 7mm hole and 5mm protruding. Very easy to waterproof, and cheap. separate switches are not what you were going for though.
ps, the pa09 and the jst set came. Wow, nice crimpers and jst's to last forever!
