48v high current switch
Projectitis
New Zealand
Hi all,
Sorry if this has been asked before - I have searched and not come up with anything yet, so feel free to point me at other threads if this is a duplicate.
I want to add a switch between the battery/BMS and the rest of the circuit (e.g. controller, 12v aux system) to kill all power when not in use. I have a 1000W motor and 48v battery, so theoretically around 20A maximum draw, so I'm thinking something that handles 30A at 48V.
Do I need something like a relay, or will a switch rated (for example) 20A at 110V work ok for 30A at ~50V? I'd much rather have a nice, relatively small rocker, than having one of those industrial ON/OFF panel switches too, that you see on table saws and other workshop equipment :)
For example -
will something like this be suitable?
I don't really want something like this!
Any ideas on suitable switches?
Thanks,
Peter
Projectitis said:
Hi all,
For example -
Thanks,
Peter
you could use sometihng like this http://www.ebay.co.uk/itm/1-x-Black-Button-4-Pin-DPST-ON-OFF-Car-Rocker-Switch-AC-250V-15-30A-K201N-/161310834782?pt=LH_DefaultDomain_3&hash=item258ee0005e and parallel the contacts should be ok for 20-30A
If you have a BMS, it already can switch off the power, so it doesn't make sense to add another switch. Show us a picture of your BMS and we can probably advise a simple way to add a switch. For that, you can use any switch you want.
