I have a 48 to 72 volt 60 amp crystalyte controller. I'm operating it on a 52 volt battery (58 fully charged) When the voltage is below about 55 volts and I shut it off, I have trouble turning it back on again. I have to play with the the switch turning it on and off for a little bit then it will make a little static sound and the crystalyte analyst will blink on and off and finally after a little time it turns on. Is there a commom cause for this?
Dan
Dan
