grwsaltspring wrote:Very interesting thread. Can anyone tell me how long the wire is from the trigger to the plug.
I'm in the process of converting my e-bike to an e-trailer and I need about 6 ft from trigger to the controller mounted on the trailer at the moment.
Cheers Greg
Russell wrote:UPDATE May 5, 2009:.... To do this I changed the 100 ohm resistor to 220 ohm and the 470 ohm to 1K-ohm.
TPA wrote:more than one source for those.
out of stock....
amberwolf wrote:Isn't it just a regular hall sensor that's in these "linear" e-brake handles? Meaning, you could use one of them as a trigger throttle? I will have to test this now that I have a couple.
GCinDC wrote:amberwolf wrote:Isn't it just a regular hall sensor that's in these "linear" e-brake handles? Meaning, you could use one of them as a trigger throttle? I will have to test this now that I have a couple.
amberwolf, i don't understand... do you have something else you can make into trigger throttle (seems to be your genious), or do you have a couple trigger throttles? (if so, wanna sell one?
GCinDC wrote:Really? eBrake levers use hall effect? I thought they were just ON/OFF!
out of stock
http://www.partsforscooters.com/111-46
out
http://www.scootercatalog.com/bladez-throttle.html
out
http://www.extremescooters.biz/bladez-t ... lever.aspx
might be in stock
http://www.trendtimes.com/bladez-throttle-lever.html
maybe
http://www.scooterpartscatalog.com/thro ... 11-46.html
wish I could be of more help
dogman wrote:I'm a well known electronic idiot, but I think the ebrake wouldn't work as a normal throttle. I just suspect it will function more as an on off, buuut.
One thing I got to thinking, related to waterproofing a throttle, was putting the throttle in a box, waterproofed more or less, and using a cable throttle from a motorcycle to activate the sealed up regular throttle. It could be a trigger throttle from a weedeater, a brake handle, a shifter, anything that pulls on a cable.
GCinDC wrote:Just called the number on the Contact Us page. The number's been disconnected. I sent them an email. Will let you know if I hear back.
Russell wrote:This place still shows them in stock;
http://www.justformotorsports.com/products.php?product=111%252d46--BLADEZ-Lever-Throttle-Assy-For-Electric-Scooter
-R
Users browsing this forum: No registered users and 12 guests
