An alternative to thumb or twist throttles
Re: An alternative to thumb or twist throttles
Postby callagga » Wed Feb 03, 2010 7:05 am
Oh - I just got a response from BH North American Corp (they're the manufacturer of the part right??) that said the Scooter Lines (in the context of the part number) were discontinued by The Bladez Corporation about three years ago, and they have limited stock on parts and we do not have that part available :cry:
Anyone know if this is correct? Or that BH North American Corp are really the manufacturer of the part Bladez part # 70171.
callagga
Postby dogman » Wed Feb 03, 2010 9:16 am
I'm a well known electronic idiot, but I think the ebrake wouldn't work as a normal throttle. I just suspect it will function more as an on off, buuut. The way I ride that could work fine :twisted: I pretty much floor it at all times commuting at least. So mabye a set up with a regular throttle when you need it, but an on off throttle with a brake handle to use when you are cruising?
One thing I got to thinking, related to waterproofing a throttle, was putting the throttle in a box, waterproofed more or less, and using a cable throttle from a motorcycle to activate the sealed up regular throttle. It could be a trigger throttle from a weedeater, a brake handle, a shifter, anything that pulls on a cable.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Postby amberwolf » Wed Feb 03, 2010 2:24 pm
dogman wrote:I'm a well known electronic idiot, but I think the ebrake wouldn't work as a normal throttle. I just suspect it will function more as an on off, buuut.
The non-linear ebrake handles would indeed work that way. But if I understand correctly, the linear ones are supposed to allow you to brake a little or a lot, just like your regular mechanical brakes. That means they must be putting out an analog signal, rather than just full off / full on.
Whether or not the signal is the right level (or polarity) to use for a throttle has yet to be determined. I'm sick enough at the moment I can only wobble to the bathroom and back here to the bed, but once I feel well enough to work on stuff without falling on it, breaking it or blowing it up, I'll test out the idea.
Polarity is easy to fix, by flipping the magnet around the other way, I think. Level might have to have op-amp scaling and offset. (well, transistors could be used instead).
That's pretty much how my original plan for my pedal-chain-tension-operated throttle would have been, with the Honda scooter cable-twist-throttle setup to pull it's lever up for an override when I didn't want to or couldn't pedal. I never have been able to build it to test the theory yet, though. Originally the box would've been a pot throttle with a lever on the outside that had a roller on top of the chain, and inside the box the pot throttle and the electronics needed to offset and scale it's output so it could be adjusted to suit the pedalling tension vs motor speed I wanted out of the system at a certain pedalling force. Plus some op-amp integration to smooth out downstroke vs rest of rotation, so it didn't get power surges.
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby callagga » Wed Feb 03, 2010 2:29 pm
Russ/all
Looks like the party may be over for the design on thread :( Called partsforscooters and they're saying they may not get the part in again and they didn't think bladez was still around. Not good timing for me cause mine needs replacing...
Anyone know of an alternative sqeeze thottle brand/model one could use instead of the Bladez?
thanks
callagga
Postby Russell » Wed Feb 03, 2010 3:25 pm
Jeep Comanche 29er w/Bafang QSWXH, 41 lbs + 9 to 14 lb rear trunk bag w/tools+battery, 29 mph w/12S LiPo.
Mongoose Hatchet dual suspension w/Bafang BPM
Past Bikes: Raleigh 700C, Kona Smoke 2-9
Russell
Postby GCinDC » Wed Feb 03, 2010 3:49 pm
Just called the number on the Contact Us page. The number's been disconnected. I sent them an email. Will let you know if I hear back.
Youtube channel, 2011 Highlights vid. Ebike Nerdcast.
Giant DH Comp: 20s lipo (10Ah), hs3540, 72V 45A 12FET, 900W BMSBattery charger.
GT I-Drive, 20s lipo, 9C, 72V 45A 12FET.
GCinDC
1 GW
1 GW
Postby callagga » Wed Feb 03, 2010 4:26 pm
GCinDC wrote:Just called the number on the Contact Us page. The number's been disconnected. I sent them an email. Will let you know if I hear back.
which company are you referring to GCinDC? thanks
callagga
Postby callagga » Wed Feb 03, 2010 4:29 pm
Thanks Russell - Unfortunately I found out they don't ship to Australia :(
callagga
Postby callagga » Wed Feb 03, 2010 4:32 pm
PS - re possible alternative I see on this site there is the following - think this could be a replacement?
http://www.justformotorsports.com/products.php?product=152%252d4--Throttle-Lever-for-Gas-scooter
callagga
Postby GCinDC » Wed Feb 03, 2010 4:53 pm
justformotorsports
GCinDC
1 GW
1 GW
Postby drewjet » Wed Feb 03, 2010 9:35 pm
Be Aware, some of the bladez used an on-off switch for a throttle. I bet the $13 one is that, I think you need the $25 one http://www.justformotorsports.com/produ ... ttle-Lever to get a three wire with pot.
ImageSuzuki SP200, Mars Brushless, 300 Amp Kelly Controller,(18S12P) http://www.evalbum.com/1511
3220 Mountain Bike viewtopic.php?f=28&t=16705&p=244317#p244317
Suzuki Lipo Upgrade viewtopic.php?f=10&t=23088&p=335986#p335986
Race Bike viewtopic.php?f=3&t=32486
drewjet
Postby amberwolf » Wed Feb 03, 2010 11:52 pm
Well, dangit, the hall sensors in these ebrakes I have are indeed the switching kind, rather than the linear kind. However, it would be dead simple to change out the hall sensor in any of this type of ebrake, based on the breakdown pics I took in a previous post.
Then they *would* work as lever throttles. :)
amberwolf
Postby redorblack » Thu Feb 04, 2010 1:16 am
http://www.justformotorsports.com/pages.php?pageid=4
The about us page had an interesting typo and the company address is misspelled or fictitious. Letting the spelling get fixed from Specially Point to Specialty Point Dr. brought up a website for a construction contractor which might be bogus also. I found it interesting that they named a different company in the middle of their about us spiel so plugged that in and that companies About Us page had the same exact spiel except being in California rather than Florida and had it's own name throughout the page..
Check it out...
http://www.motopartsmax.com/index.php/m ... chapter/10
And that one goes data mining if you want to be a dealer, but there they are Ridemax-inc.com.
I'd love to have one of these trigger throttles, but I'm HIGHLY suspicious of these websites, too many red flags.
Any ideas?
Scott
redorblack
Postby drewjet » Thu Mar 11, 2010 11:01 am
If anyone is still looking I just found these with them in stock
http://www.trendtimes.com/bladez-throttle-lever.html
$13 for shipping 2 of them...ouch
drewjet
Postby amberwolf » Thu Mar 11, 2010 2:54 pm
And you might want to read what was posted about the company in the post directly above yours.... ;)
amberwolf
Postby GCinDC » Thu Mar 11, 2010 3:19 pm
drewjet wrote:If anyone is still looking I just found these with them in stock
How do you know they're in stock? They display that or did you call them?
GCinDC
1 GW
1 GW
Postby drewjet » Thu Mar 11, 2010 4:31 pm
drewjet
Postby drewjet » Thu Mar 11, 2010 4:35 pm
I called this company and they confirmed stock. When I get them in I will post
Double check the link
is correct
Interestingliy the just for motor sports is supposedly about 10 miles from my house. I tried the number and it was disconected
drewjet
Postby redorblack » Sun Mar 14, 2010 7:10 am
drewjet wrote:I called this company and they confirmed stock. When I get them in I will post
is correct
Could you find or get an address for Trendtimes? I couldn't locate one on their website...
redorblack
Postby drewjet » Mon Mar 15, 2010 3:21 pm
Just got a call from trend times and they ended up not having them, they credited my CC so all is well, just have to start looking again.
drewjet
Postby drewjet » Fri Mar 19, 2010 4:17 pm
drewjet wrote:Just got a call from trend times and they ended up not having them, they credited my CC so all is well, just have to start looking again.
I just received in 2 in the mail from http://www.bladezscooters.com/
drewjet
Postby GCinDC » Fri Mar 19, 2010 8:31 pm
Thanks for the heads up. Let us know how it works out for you.
I want one, but am suddenly balking at $39 shipped. Also, I wonder how it would hold up in rain...
GCinDC
1 GW
1 GW
Postby auraslip » Sun Apr 18, 2010 3:35 pm
I just wanted to subscribe to this threat and say good job russel.
auraslip
1.21 GW
1.21 GW
Postby Russell » Sun Apr 18, 2010 7:10 pm
Thanks Auraslip, it's the only throttle I use and I absolutely would not want to ride with a conventional throttle. I've put a combined 5,000 miles on the two units I have with one now as a spare. I guess they are hard to come by now so I'm glad I have another just in case.
-R
Russell
Postby auraslip » Sun Apr 18, 2010 8:00 pm
The updated retailer in your first post still seems to have them for 13.99.
Or does that one not work?
auraslip
1.21 GW
1.21 GW
PreviousNext
Return to E-Bike Technical
Who is online
Users browsing this forum: No registered users and 4 guests
