John in CR wrote:I understand that it's the current through the windings creating most of the losses in a motor, but since they have a torque constant, why is it wrong to look at power out from the battery as long as you consider the motor's efficiency curve?
John in CR wrote:Arlo1,
That's why I handed you the shovel, just for the entertainment value in seeing you dig the hole deeper. BTW, just like I said before:
1. You owned those holes as soon as you made them bigger to copy your hero Methods.
2. During your wheelie sessions you're not running anywhere near the power you claim.
El_Steak wrote:OK, got to go give some time to the GF, shes not too impressed with my testing...
John in CR wrote:The higher peak amps is interesting. I wonder if that's just because of cooler windings lowering the resistance. Did you notice any difference in how hard the bike pulled?
John in CR wrote:How about the sonics, did you get any whistling? Did it change that other noise the 9c is known for, or did yours not do it to begin with?
John in CR wrote:Can I get you to do 1 pic? I'd like to see the cover from the outside but with the view parallel to the motor. I want to see where the hole placement is in relation to the flange where the cover's bolt holes are. I ask because I think you can draw the flow out from even closer to the windings by butting those holes right up to that flange where the cover is near perpendicular.
John in CR wrote:One other question, how did the covers feel to the touch? That's really all I know, since I've yet to use a temp gauge, which will change shortly.
ZapPat wrote:So El-Steak, will the next run be with the mid-radius holes plugged up? These extra holes in the middle may be reducing the effectiveness of the other well-placed holes, maybe?
John in CR wrote:I don't think the relationship of current and efficiency can be stated that way. eg A motor's efficiency doesn't change a lot between it's points of maximum power and maximum efficiency, but current changes a good bit. Otherwise I think we're saying the same things just from different viewpoints.
I think a confusing part is how controllers do that current multiplication thing at takeoff to generate more torque, but doesn't it do that by reducing the effective voltage for a certain power from the battery?
Yes those motor losses are high due to low rpm, but there's also more work getting done due to the higher torque than if the current multiplier was turned lower, making the increased losses have a shorter duration to reach the same speed. Overall losses are the same for a slower lower current acceleration to that speed, because the same work is done over the same efficiency curve related to RPM.
markcycle wrote:it's my observation that the big problem with these motor is not the winding temperature per say, but the magnet temperature, as above 80C the magnet start to demagnetize. I have found with the motors I sell that the winding can sustain 140C measured and peaks of 160C. But if the magnets get above 80C then a degenerating effect begins because of the magnet getting weaker the motor needs more current hence more heat and this positive feedback continues until the motors finally burns out or the magnet let go and spin.
Air cooling holes in the side covers helps keep the magnet below 80C preventing this degenerating effect. With air cooling I can regularly see 125C on the winding but can keep the magnets below 70C. without air cooling I have to set the thermal shutdown at a winding temp of 100C to prevent the magnet form going over 80C.
I have been running air cooling holes on my test motorcycle for a year now (3000 miles) and have found that with good screens over the holes there is no problem with dirt or rain. I regularly inspect the windings and they look amazingly clean.
Mark
El_Steak wrote:John in CR wrote:Can I get you to do 1 pic? I'd like to see the cover from the outside but with the view parallel to the motor. I want to see where the hole placement is in relation to the flange where the cover's bolt holes are. I ask because I think you can draw the flow out from even closer to the windings by butting those holes right up to that flange where the cover is near perpendicular.
Not sure if that is what you were looking for, but I added the pic in the test thread under "Run C"
Users browsing this forum: jeohearn and 13 guests
