The Mighty Volt wrote:what's the name of that conical tool used to drill the holes? Thanks.
Do you mean a step drill? Here is a link to the one I used.
adrian_sm wrote:The Mighty Volt wrote:what's the name of that conical tool used to drill the holes? Thanks.
icecube57 wrote:Would scoops like this help force air into the hub.
El_Steak wrote:thx, I'm just 5'7" hence the 150 pound.
It wasn't too hard actually, I'm just counting my calories using a little ipod application.
oldpiper wrote:El_Steak wrote:thx, I'm just 5'7" hence the 150 pound.
That's why I find it so hard to lose weight,I don't have an iPod! Thanks, El Steak!
Cameron
docnjoj wrote:Our bikes may be the only thing that save us from sure death or disability.
Hyena wrote:Good for you guys, my bike will CAUSE me sure death or disability
LarsE wrote:Hi
Some cooling modifications to my rear hub motor that I am working on..
Uploaded with ImageShack.us]
The cooling is 48 of http://www.dealextreme.com/p/aluminum-cooler-heat-sink-chipset-for-ram-memory-square-type-8-piece-set-35817
They are grinded to the radius of the hubmotor 16cm with a homemade tool that fits a cordless drill and then glued on with arctic alumina.
My side panels is of course vented with big holes to let ear inn and out.
Its been a lot of work, (the grinding) so I am hoping it will take some kW without overheating.
LarsE wrote:Hi
Tomorrow when the epoxy has set, I will glue this metal disk over the blades. It will serve 2 purposes:
1- Secure all the blades together and prevent a single blade from coming loose and trashing the windings
2- "Channel" the fresh air directly to the windings instead of the stator.
¸Doctorbass wrote:So you can say that this blades principle also offer amazing braking force advantage?
Users browsing this forum: Andje, cal3thousand, perbear and 12 guests
