stew007 wrote:The oil cooling could work, but! you have to take into consideration the effect of the viscosity of the oil/coolant acting between the stator and the magnets as it is a tight gap, so it will act like a torque converter, like which joins your auto transmission to the engine of your car, which may reduce your efficiency, the faster you go, the more friction would be generated.
Also, Air, when it is enclosed acts as an excellent insulator, thats the reason why double glazing is so effective, and other insulations act to trap air in order to retain heat. So any form of cooling fins to act on a sealed air cavity will probably have little effect. The most effective way would be to remove the hot air from inside the casing. If the shaft was bored and joined with flexible tubing to an air intake formed on the front of the bike in the form of an air scoop (with a particulate filter), the exit holes could be on the motor plates near the windings (so the air passes over the windings to get out, with mesh screens over the holes), this would enable proper air cooling, and at the same time remove the possibility of dust getting in. Also an inline fan (many high output RC ducted fan kits would be ideal for extreme CFM!) coupled to a thermostat on the motor could be used to assist the ram air effect from the forward motion of the bike during times of extreme ebiking
. So this system could be set up so it is totally automated, and would be great for extreme high power setups
Thats not quite how Torque converters work... They dont really use friction as the driving force, they use the momentum of the fluid pushing against fins. (From what I gather watching this vid
http://www.youtube.com/watch?v=MvLoX0z9qoY)
Come on people don't give the oil cooling idea the back seat!
I know the thread is about air cooling but this could be a lot easier and more effective! I think it has potential to provide excellent heat transfer from the stator to the outside of the casing, rather than the insulation that the air provides. The only problem it might cause is if it degrades the adhesives in the motor which seems highly unlikely, Reid Welch has flooded his Ezee hub with oil and kept it partially filled for a couple months and has had no problems yet. He has also observed no loss in efficiency while running the motor with little oil in it.
http://endless-sphere.com/forums/viewtopic.php?f=6&t=7454&hilit=ping+battery&start=255#p148040
- THE YELLOW LINE is the oil would be.
- ebmstru.jpg (108.08 KiB) Viewed 1021 times
I think its worth considering that the oil might not add much friction to the system because any friction would occur between the flat, continuous surface of the magnets and the surface of the stator. You would only add enough oil to just touch those two surfaces when the motor is spinning fast. From the crystalyte website I see that the "available" rotors on the LEFT have nice flat surfaces. I suspect the ones on the right are very rare.
The other surface the oil would touching at high speed is this the stator. It seems to have a nice flat surface too. Not sure if the slots in the stator would cause much friction but if they do they could be filled with something so the surface is completely flat.
All I'm saying is it seems like having oil in there would be nice and frictionless. I know some chemical engineers and I can ask them if they think oil could degrade any type of adhesive, which is pretty unlikely because that would be a quite a design flaw for an adhesive.
