www.evlogix.com
So, I'm guessing many want a cheap throttle converter that allows them to use a standard e-bike throttle on an RC controller box.
And I think I can do that while still adding quite a bit of features you won't get with a hacked together converter. Essential ones that can protect your pricey $100-$200 ESCs!
The difference will be that it won't limit based on current, it'll be a normal throttle-to-throttle converter that's for those that don't need current limiting like high-powered setups with powerful batteries with appropriately sized and cooled motors. So, I ask, what features do you want?
I think I can still keep a temperature sensor for protection and you could also add another temperature sensor if you wanted to. I can also keep LVC, or Low Voltage Cutoff.
Do you guys need capacitors or would you prefer that being an "extra"? I'd think they'd be necessary and it'd be nice to get the whole shebang done in one swoop, but the enclosures and capacitors cost money and I'm not sure everyone is adding capacitors and I think some have their own enclosure they want to use. I think I can add pads so you guys could install your own capacitors if you wanted to and you could provide your own enclosure. But let me you know what you guys prefer - adding capacitors and an enclosure would add an extra $10-15 to the cost as there's labor involved or you could DIY if you wanted to do it for cheaper. Also, do you need on-the-fly end-point adjustment like say with a pot?
I can still add the double-twist of the throttle to get a "boost", a throttle boost that is. It'd probably be less noticeable than a current boost in most situations, but it'd be nice to have. Also, I can keep the customizable throttle ramp or you could turn it off. It'd still be programmable, if you guys want to.
So, tell me what features you still want for an economy version.
Also, this could get small and it'd still work in cold weather, unlike some common RC equipment that isn't designed for the cold.
