Stinky Turnigy 80-100 -Nuvinci semi auto
Re: Stinky Turnigy 80-100 -Nuvinci semi auto
Postby Burtie » Mon Dec 05, 2011 8:53 am
drewjet wrote:bURTIE,
How many watts are you putting into the Nuvinci? What kind of speeds are you hitting?
...Could you check the hub temp next time you ride for around 10 miles?
Thanks Drew
Hi drew,
I have temporarily dialed down the power to stop the chain slipping, so it is now only about 2.8kw, and gets to about 32mph max on the flat.
NV hub probably gets about 5 deg C above ambient after 3 or 4 miles.
Burtie
Postby drewjet » Mon Dec 05, 2011 2:00 pm
Thanks Burtie. I am currious to see how it goes once you get your chain sorted out and put some more power through it.
ImageSuzuki SP200, Mars Brushless, 300 Amp Kelly Controller,(18S12P) http://www.evalbum.com/1511
3220 Mountain Bike viewtopic.php?f=28&t=16705&p=244317#p244317
Suzuki Lipo Upgrade viewtopic.php?f=10&t=23088&p=335986#p335986
Race Bike viewtopic.php?f=3&t=32486
drewjet
Postby lostrack » Thu Feb 02, 2012 4:32 pm
Very cool - I'm going through this chain tension issue right now. Alignment and tension really helps.
How did you fix it in the end?
lostrack
Postby Burtie » Thu Feb 02, 2012 4:49 pm
I haven't fixed it,
I just turned the motor torque (phase current limit) down until it stopped slipping.
Still great fun, but it would be nicer to fix it somehow so I could use full power :?
Wierd thing is, that I managed to put more torque though my old 8 speed derailur setup than I can now with this bmx chain.
Burtie
Postby lostrack » Thu Feb 02, 2012 5:01 pm
Wow, a few months and still no fix?
I have been improving my setup and realised that the chain line has to be millimetre perfect, laterally, and then add as much tension as possible before drag becomes too much.
Secondly, the bike with no weight on worked fine, but due to the spring setup, the chain pulling tension reduced Much more when I sat on it, making the pull weak. Jumping off, it's fine. so, leaning forward when accelerating fine, leaning back, skippy chain.
Going to add more chain tension or try and change the design so it's an equal pull the whole of the spring travel.
Sorry if this doesn't make complete sense, half watching tv...
lostrack
Postby rodgah » Thu Feb 02, 2012 5:02 pm
are you sure its the rear slipping?
Common Sense isn't so common........
Image Image Image
rodgah
Postby Burtie » Thu Feb 02, 2012 5:15 pm
rodgah wrote:are you sure its the rear slipping?
Yeah pretty sure.
I flipped the front 44t chainwheel over, so it is using the unworn side of the teeth on the pulling side, no change.
Beginning to think the only way to fix this will be to use substatialy larger diameter rear sprocket somehow.
I guess this chainslip may not be a problem in applications where you have no chain growth, and you can use a fixed tensioner.
But with this suspension bike, the need for a spring loaded tensioner is causing problems.
Burtie
Postby rodgah » Thu Feb 02, 2012 6:00 pm
i really dont understand how it could of changed from the derailleur.....sure if you were experiencing problems with the same tooth count on the cluster it would make sense. Have you tried putting the cluster back on and locking the derailleur on a similar T gear (like you have already done) and see if it slips? I am amazed that the short little funny shape teeth on gear clusters hold pedalling power let alone motoring power.
Rodger
Image Image Image
rodgah
Postby lostrack » Thu Feb 02, 2012 6:03 pm
Yeah pretty sure.
Check with your weight on the bike it's still pulling as hard as you need.
lostrack
Postby Burtie » Thu Feb 02, 2012 6:26 pm
I did have an external coil spring on the derailleur, applying some serious chain tension, to the point where I thought the idler bearings would suffer badly. It helped a bit, but did not eliminate the skip.
I get the feeling that since I have done a few 10's of miles on this setup, the chain and sprockets are bedding in an the situation is improving slightly, but I am probably clutching at staws here.
I might try re-fitting the external spring to refresh my assessment.
Burtie
Postby kfong » Sat Apr 14, 2012 10:44 am
How old is the chain Bertie? I used a chain tool to measure the streaching. I've had to replace my bike chain twice already on my cyclone setup. This could be the cause of your skipping. You will be surprised at how much a chain can streach from hard use.
kfong
Postby Burtie » Sun Apr 15, 2012 4:42 am
I used new chain(s) and several new sprockets.
I removed the Lipo to use on another bike, so haven't played with it for a while now.
The plan is, to re-engineer the gearing so I can use a much bigger rear sprocket. That should enable me to transmit a decent amount of power to the wheel before the chain acts up.
Burtie
Burtie
Postby Kin » Sun Apr 15, 2012 11:31 am
Just wondering, did you have any shots of how you added the external bearing support on the other end of the shaft? I couldn't tell from the photos on the first page.
Also, what were those two notches on the non-power side of the 80-100 shaft?
Coolios build.
New to endless-sphere? Notice a lot of signatures recommending Ebike.ca? That's because it's the best place for a quality and manageable, (but still 'real'), first build. Justin is a solid supporter of electric bike development, and a good source of equipment.
My hat off a thousand times to the green people that effectively run this forum. The ES Mods are superb.
Kin
Postby Burtie » Thu Jun 28, 2012 3:29 pm
Kin, sorry I missed that last question :oops:
Support bearings are sandwitched between the two plates at each end of the motor, see in this photo:
viewtopic.php?f=28&t=12768#p189713
Tho I have now removed the bearing from the back end, as it is not really needed.
The notches are for the grub screws on the bell to engage with. Standard feature on this motor (photo shows shaft inserted backwards in bell)
Fresh look at the slipping chain problem revealed a couple of stiff links in the primary , it was actually the primary chain that was slipping :oops:
Now cured.
Burtie
Postby kfong » Sat Jul 07, 2012 7:40 am
Good to know it's fixed. Thudster is rewinding my burnt out motor so I can finally join in on the RC fun.
kfong
Previous
Who is online
Users browsing this forum: comradegerry, ikxdf, sabongi, speedmd, waynebergman and 6 guests
