Burtie wrote:gwhy!,
The voltage in the video was 24.
I wonder if the stator lamination material is different in the new style 80-85 motors, the cogging seems to be very much less (perhaps only 10% ) than the older 80-100 motor that I have. Could this account for the higher no-load current?
The lamination thickness looks to be the same, and the magnets appear to be of a similar strength.
What modifications did you make to your 6 FET controller and how has the performance changed?
Burtie wrote:
Previously with the sensorless ESC the startup from stopped was very violent and unpredictable, you had to carefull not to end up on your arse!
Burtie wrote:The other benefit I am expecting Is that the motor will no longer lose sync under rapid acceleration.
Thud wrote:Thanks for the update Bertie.
figured you were out riding as its been awfully quiet lately.
dbaker wrote:Wow! It must wheelie pretty good! 12 fet controller? What voltage are you running and what are the controller parameters you set?
Burtie wrote:And, so it was, that after busting my freewheel, I discovered that I had also ridden through a huge pile of dog shit
http://www.youtube.com/watch?v=BFDsjOW1Q7Q
Burtie
Miles wrote:Yes, we need the full autopsy report, Burtie. Valuable info....![]()
etard wrote:
Does that bike fell comfortable? It almost looks like you could go a size bigger. Especially with all that nose lifting nonsense.
KiM wrote:
p.s this is the exact spacing on the halls sensor mount, as you posted my way mate?
EDiT: i should get some t-shirts printed Burtie..."I 'd rather push my RC motored bike home than
ride a frock powered bike"
Users browsing this forum: arkmundi, Bing [Bot], boostjuice, Google [Bot] and 6 guests
