Hi All
Long time since I have had time to do a post (Is that you I hear cheering KiM?? LOL)
With the release of V3 I am now also in a position to start offering parts to buyers who don't have an eLation system.
I thought this would be a good place to start. In V2 I was using an off the shelf CSK-PP35 with keyway on both rings. For V3 I have had a tailored Sprag clutch manufactured.
It is based around the CSK-PP35 but with dimenions more suited to bike components.
- IMG_0380.JPG (49.47 KiB) Viewed 1204 times
Detail:
OD 62mm
ID 1.37", 24TPI. This lines up with standard bike threads
Width 15mm. This is 1mm norrower than standard to allow to give 'perfect' fit to cranks able to accept freewheels.
Outer ring Keyway 8mm wide, 1mm deep
Combined bearing and sprag with seals on each side
They have saved me a lot of time and cost avoiding keys and 'special parts' being made, and so I felt worth the cost. Some on here may not agree, going with the lower cost due to no consideration to valueing their own time, since it is a hobby.
I can sell at AUD$50 plus postage. As an idea, postage to USA or UK could be as low as AUD$12 by standard air mail.
NOTE:
Once the bearing is on, it is not the easiest to remove as there are no tags, etc to allow easy undoing. I considered this at time of design, but felt for eLation needs it was not needed as we sell the crank 'spider' as a complete unit. It does not mean it can't be removed (awkwardly during assembly), but is pretty much there to stay once operational. For the time being, based on eLation's needs this is not needed to change. However, if there is enough interest I can review this choice and have a batch done to accomodate removal.
At present for my prototyping needs I uses a grinding wheel to cut a couple of goove on inner ring edge to allow for tools to remove
