Electric downhill/freeride bike
Re: Electric downhill/freeride bike
Postby Whiplash » Thu Mar 22, 2012 8:00 am
What does a pack like that weigh? It looks heat, why not LiPo?
Power is a fascinating thing, the more you have, the more you want, but the real power is having the restraint not to use it all at once...............Um...Yeah..
The harder you work.....The luckier you get!!
"People who say it can't be done are often interrupted by those that have already figured out how to do it!"
Email me @ currentcycles@gmail.com
OR check out http://www.CurrentCycles.net
Whiplash
Postby Ratking » Thu Mar 22, 2012 3:24 pm
Whiplash wrote:What does a pack like that weigh? It looks heat, why not LiPo?
Compared to the hard case lipos I've would been using there are only a few grams difference. My pack is 8.4 kg and the lipos would only be a few hundred grams less for the same capacity.
Some of the reasons are that I designed the frame around these cells, and there are no lipo packs that fi good enough for me using them. If the bike is perfect and I see a need for another one, I will make one a bit wider so that it will fit two hardcase packs in the width of the frame making it possible to have 1.5 kwh++. That all the batteries was free for me also helped :)
PS. What do you mean by "It looks heat?"
Ratking
Postby Whiplash » Thu Mar 22, 2012 5:07 pm
Sorry, autocorrect on my phone... I meant they look heavy but they aren't! Nice build especially considering the cells were free!
Whiplash
Postby Ratking » Wed Mar 28, 2012 5:27 am
Batteries are almost complete, I will show how I did it for anyone that wants some inspiration how it could be done.
I first tried to solder all the balancing leads to the tabs, but the wire plus solder was to thick for my frame if I wanted a sheet of protecting plastic so I had to make an alternative. Then I came up with his route.
I think its much cleaner and should be atleast as good. I'm starting to love spot welding. Its so easy and clean.
I tried to discharge the pack, and I got between 9-10Ah at 1.2C out of a 12s6p pack of konions. That was from 4.125v-3.17v. I did not want to go to low, even though the data sheet says 4.2-2.5v.
Ratking
Postby Ratking » Wed Mar 28, 2012 5:56 am
Just spamming my own post, need to update my build with the newest from Ratking's workshop.
Since I have limited space, and wanted both a freewheel and torque limiter I had to think new and hope this solution is the best compromise.
Short explanation:
First part is the sprocket adapter for the 25# sprocket, and on the same adapter a 30mm one way bearing is pressed on. A outer adapter is pressed at the outer part of the one way bearing and the torque limiter is fitted with a 420 sprocket.
I still need to make the last part that compress the two disks and the sprocket, but that is a small part to make.
The whole part is less than 40mm thick, I can see any way to make this any slimmer. I hope it does a descent job.
Ratking
Postby Andje » Wed Mar 28, 2012 7:32 am
Hello!
I have been following your build, it's very impressive. I am also working with the 18650v cells you are using. I am planning on CD welding tabs as well, basically we are following similar battery paths.
I liked your balance leads at first, but I foresee a potential issue. Where you have bent those tabs over the edge at the 90 degree angle, they are pressing directly against the thin plastic layer. With vibration I am worried the sharp edges of the tab might slowly but surely cut through the plastic; i have seen this on several Makita packs, where the sharp edge of a tab eventually cut through the green plastic and shorted the pack to the negative body housing, and thsoe tabs were on top, horizontal to the plastic layer and they still cut through. I would think one thin insulating layer like electrical tape would at least double the shorting protection, but I would be generally weary about bending those tabs like that at all; the edge might end up slightly rounded, causing the sharp edges of the tabs to actually slightly point inwards towards the plastic...
Anyway, maybe I'm just being paranoid, but I'd hate to see you lose free batts :). What do you think?
Norco 125 Dirt Jumper
100v 15ah Lipo Backpack
lyens 18 fet, 100v 100 amps, R12 Regen
x5304- 95km/h
http://endless-sphere.com/forums/viewtopic.php?f=3&t=24594
Norco A-Line Park 2009
144v Kelly 300amp
5403/ future HS60
http://endless-sphere.com/forums/viewtopic.php?f=6&t=35652
Andje
Postby Ratking » Wed Mar 28, 2012 7:56 am
Andje wrote:Hello!
Nice observation, but I have welded all the balance leads to the negative side of the battery, so if any of the leads get trough the black tape and the green plastic it doesn't do anything, because it the same potential. And I also welded the nickel sheet on top of the already existing tabs, I don't see that it could make any short easily.
This is a experiment from my side. It only costs my time, and that is ok for now.
If it fails, I will be one step closer to a better pack.
Ratking
Postby Ratking » Wed Mar 28, 2012 8:26 am
Just tried to spot weld some thin copper sheet(.2mm) and it worked prey good. I don't know what characterise a good weld, but when the copper
rather want to be on the battery tab than keeping the sheet in one piece I would say it it good.
I would love to get some input on this, because I have always heard that copper is hard to spot weld whit this kind of welder.
Ratking
Postby Ratking » Sat Mar 31, 2012 8:26 am
Just go myself a little package containing a few 52t 130 bcd rear sprockets.
Did you know that two ordinary bike sprockets sandwiched together have the same physical size as a 420 motorcycle sprocket?
I also got my 300A shunt for measuring current draw from the packs.
Ratking
Postby kfong » Sat Mar 31, 2012 9:20 am
Nice freewheel solution, where did you source the parts, especially the one way bearing?
kfong
Postby Ratking » Sat Mar 31, 2012 7:15 pm
kfong wrote:Nice freewheel solution, where did you source the parts, especially the one way bearing?
Hello
I've been taking the sprocket and clutch disks from a Dalton OSD 225, 30mm id one way bearing from VXB.com, and a 25# sprocket is just standard item.
The rest is custom made in a lathe.
Since I know a lot more now than I did when I started, I would just buy the sprockets from the cheapest source, and buy the one way bearing and clutch disk separate.
I bought a lot more that I did not use, but I guess its live and learn.
I did make the torque limiter almost ready to rock, just need some finishing touches. Its a tad heavy, I'm gonna take a big drill-bit and make it light.
I also made my first keyway today. Not very pretty, but it should work out okay.
Please tell me if you wan't pictures, I would like to know if there is any interest and what you want to see.
Ratking
Postby kfong » Sun Apr 01, 2012 7:48 am
Nice machine work. I assume the screws are to tension your custom clutch. More details on that would be nice. Where did you source the clutch material. Are you using one or two clutch pads. How has this been working out for you. The area seems very small to be effective, but I have no experience using one.
kfong
Postby Ratking » Sun Apr 01, 2012 10:27 am
kfong wrote:Nice machine work. I assume the screws are to tension your custom clutch. More details on that would be nice. Where did you source the clutch material. Are you using one or two clutch pads. How has this been working out for you. The area seems very small to be effective, but I have no experience using one.
Yes, that is correct. It's still experimental, but I would guess that 8xM3 screws would clamp the pads tight enough to prevent too much slippage.
The spec-sheet claim 35 foot-pounds and thats about 48Nm(http://daltongear.thomasnet.com/viewitems/-overload-safety-devices-torque-limiters-couplings/dalton-model-osd-overload-safety-device)
My two motors should peak at 15Nm total and with the first gearing being 50/14=3.57-1 the total torque the sprocket sees is 3.57*15=53.5Nm
It's a bit over the rated limit, but I have no choice other than try it out. Matt uses the same setup with great success, all though he only uses one astro motor.
It use two pads, the same as the one showed in the link
Ratking
Postby kfong » Sun Apr 01, 2012 11:11 am
Are the pads glued down to the metal or are they allowed to freely rotate, did you source the pads from Dalton or make your own. I might need to do this for my RC build if I find the direct connection to be too harsh for the motor.
kfong
Postby Ratking » Fri Apr 06, 2012 12:08 pm
kfong wrote:Are the pads glued down to the metal or are they allowed to freely rotate, did you source the pads from Dalton or make your own. I might need to do this for my RC build if I find the direct connection to be too harsh for the motor.
I did buy a complete unit from dalton, and modified it until only the pads was left.
Been doing some more time consuming work at the bike too.
I have shorten and dimpled the axle at four places. Two for the sprocket and two for the end bell of the motor.
Hope that is sufficient for the torque the motor produces, time will show.
I tried the parts on the bike, I need a clever chain tension system, and I got an idea for it.
Rear swing arm is welded by a friend of me, it seems so easy when he does tig welding, I have to learn that some day.
Ratking
Postby Whiplash » Fri Apr 06, 2012 3:05 pm
Awesome work! great looking and precise! Is the #25 chain strong enough for that application though with two motors? I guess it IS before the major reduction but it seems a possible weak point? I would assume you are planning on running around 10,000 watts or more since the motors will handle 5K a piece, seems like a stretch for the chain (no pun intended)..
Whiplash
Postby Ratking » Fri Apr 06, 2012 7:37 pm
Whiplash wrote:Awesome work! great looking and precise! Is the #25 chain strong enough for that application though with two motors? I guess it IS before the major reduction but it seems a possible weak point? I would assume you are planning on running around 10,000 watts or more since the motors will handle 5K a piece, seems like a stretch for the chain (no pun intended)..
Thanks, I appreciate it :D
I can't answer you at this point, but maybe in a few weeks :P
My goal is to make a compact system that can take a beating, so if it breaks I will have to go to the next level.
I hope the torque limiter takes care of the roughest peaks of torque.
I have an idea for belt drive, but I hope this is strong enough as planned.
Ratking
Postby geetarboy » Thu Apr 12, 2012 8:03 pm
Awesome job Ratking, I like the way you integrated the suspension. That bike should handle like a dream, all the weight is is in the right place. excellent!
geetarboy
Postby E-racer » Thu Apr 12, 2012 9:49 pm
cannot wait to see this thing run!
Kona Stinky: custom swing arm w/ batteries
-13s3p Turnigy Li-po
-Turnigy 80-100 rewound 130kv (Burtie's optical board)
-Kelly KBL 48201
-Nuvinci Dev Kit
http://endless-sphere.com/forums/viewtopic.php?f=28&t=35341
Goped ESR750
-12s2p Turnigy Li-po
-Turnigy 80-100 HXT w/halls
-Kelly KBL 48201
http://endless-sphere.com/forums/viewtopic.php?f=35&t=20732
E-racer
Postby Ratking » Fri Apr 13, 2012 3:09 am
E-racer wrote:cannot wait to see this thing run!
Can't wait myself, too bad the Easter went away with a cold and that several exams are comming up shortly, little time for the bike at the moment.
Still waiting for the new CA, thats gonna be nice tool to have in my arsenal
Ratking
Postby Ratking » Fri Apr 13, 2012 3:11 am
geetarboy wrote:Awesome job Ratking, I like the way you integrated the suspension. That bike should handle like a dream, all the weight is is in the right place. excellent!
Thanks, I hope it handles like a fat big hit :)
Would like to have more than 1.25kw of battery, but done is done. Have to be the next frame
Ratking
Postby Ratking » Tue May 15, 2012 6:27 pm
Hello guys!
I got a fair bit done today, but not much to show for it.
I did make my first keyed slot, both in an axle and two sprockets. I have made slots before, but not inside a sprocket/hub.
It was fairly easy with the right tool.
There is just a few more things to do before I can take it for a ride, much will come together the next days.
I am waiting for the freewheels, but I will get them soon enough.
Some pictures:
Making the slot with a press and a heavy duty toothed "saw"
This is axle is made of an incredible hard steel. Could not mill it with any bit I tried. Had to go for a stainless one instead.
Ratking
Postby Ratking » Wed May 16, 2012 6:01 am
Hello guys!
I got a big boost when I could sit on the bike for the first time. I just mounted the wheels and frontfork, still many pieces left off, but it was a great feeling to know that almost all the mechanical work is done. I have a few details, and a lot of soldering left, but that is nothing compared to all this.
As is, in the picture, with one of the motors fitted, and only missing pedals and a few misc parts it weights in at 24.6kg. Compared to the 21kg of the original bike, i think I am doing well enough. On top of that there will be 12kg battery, 1.5kg motor, controllers+ misc 3kg.
From that I think I could manage to get under +/-42kg ready to drive. I am so exited :D
Outside in the sun for the first time
Ratking
Postby geetarboy » Wed May 16, 2012 2:41 pm
Looks good Ratking, weighs about the same as my green bike loaded w/ 24s 10ah lipo 86lbs. What's the wheelbase & rake angle?
geetarboy
Postby Ratking » Thu May 17, 2012 11:08 am
geetarboy wrote:Looks good Ratking, weighs about the same as my green bike loaded w/ 24s 10ah lipo 86lbs. What's the wheelbase & rake angle?
I've tried to keep the original design from the big hit frame I took the design from, only difference is the frame that is made 30mm longer behind the cranks.
The rake angle is around 67-68 degrees. Should be good for some offroad rampage.
Ratking
PreviousNext
Who is online
Users browsing this forum: waynebergman and 7 guests
