adrian_sm wrote:Sorry to drag this off-topic so early in the thread but.... Nice news on the light. What input voltage does it take? Or are you tailoring the voltage to the high current rails you have available in your interface.
The reason I ask is I am still aiming for a minimalist DIY version of my friction drive for some reason. And it would be good to run a headlight straight off the ESC-BEC.
At the moment the best bet I have found are something like these that just came out, 3-7.2V input:
Eastward YJ-E02 MC-E
Eastward YJ-E01 SSC P7
or one of the older MagicShine "900 lumen" which I have been really happy with, and runs happily of 6V.
MJ-808 HA-III SSC P7-C
- Adrian
Miles wrote:Rotary power
The formula for rotary power is:
Power (Watts) = Torque (Nm) x Angular Velocity (radians per sec)
Solved for torque:
Nm = Watts * 60 / rpm / 2pi , or
Nm = 9.549 * Watts / rpm.
Hillhater wrote:having checked the theory ,.. it would seem that for these motors torque is proportional to power (watts) divided by RPM.Miles wrote:Rotary power
Solved for torque:
so, assuming that generally the power is limited by battery & controller capacity ( EG: 20v & 100A peak) = 2kW peak then the Torque is inversely proportional to the RPM ..and hence the kV rating
Therefore the motor with the lower kV of 170 will have 18% more torque than the 200kv version at the same voltage and current ( all other factors remaining constant)
.... and compared to a 250kV motor,..it will have 47% more torque !.. That is worth knowing i think for these friction drives with fixed gearing...(and since i have the 250 kV motor !
In Summary.. the lower kV motor should be able to give significantly better hill climbing and acceleration than the higher kV versions.
Any indications of this , Kepler ??
PS.. the links to the Leader hobby site are down ??
Kepler wrote:Its very hard for me to tell if the 170kv accelerate harder or climbs better then the 200kv motor. This is mainly due to current limiting automatically coming into play under acceleration and climbing hills..
.... and compared to a 250kV motor,..it will have 47% more torque ! .. That is worth knowing i think for these friction drives with fixed gearing...(and since i have the 250 kV motor ! )
Kepler wrote:It looks like the ones from Leader Hobby are the only ones with Skirt bearings
Users browsing this forum: DrkAngel, Electric Junk and 4 guests
