Turnigy 80-100-B 130Kv Torque rating?
Postby damonjackson_spl » Tue Feb 08, 2011 7:32 pm
I am ordering my the one way bearings for my single stage reduction..
EDIT***** now duel stage reduction.
I have found a good bearing but I want to see if it is up to the job..
I got the equation to calculate the nm of torque for the single reduction but I need the torque rating for the motor?
I have googled it with poor results..
anyone know the torque?
cheers
D
Last edited by damonjackson_spl on Fri Feb 25, 2011 5:24 pm, edited 1 time in total.
the ALL MOUNTAIN - Commencal meta 55
the BMX - Sputnic Skyline (park)
the City - Kona Dew Deluxe 29er
the Ebike - Santosa ALPHA FD (dirt jumper)
damonjackson_spl
Re: Turnigy 80-100-B 130Kv Torque rating?
Postby adrian_sm » Tue Feb 08, 2011 7:47 pm
This might help:
http://endless-sphere.com/forums/viewtopic.php?f=10&t=18609&start=15#p273455
Jermey Harris wrote:Luckily, there is a fixed relationship (for a PM motor) between the voltage constant, Kv, and the torque constant, Kt. If you know Kv you can work out Kt fairly easily. Here is the formula, for Kt in N-m per amp:
Kt (N-m/amp) = 9.5478 / Kv
so, if you have a PM motor with a Kv of 50, then it's Kt = 9.5478 / 50 = 0.191 N-m/amp
So for your 130Kv motor, your Kt = 0.073 N.m/Amp.
The question then is ... How many amps are you going to throw at it? :evil:
Build #1 ~28kg ~ 700w Avanti Hardtail Crystalyte 408, 48V10Ah Headway. ~5500 kms to date. (retired)
Build #2 ~30kg ~2000w Giant AC Dually Crystalyte 408, 48V10Ah Headway + 6s10Ah LiPo = 70V. ~15000 kms to date [SOLD]
Build #3 ~13kg ~2000w Commuter Booster <1kg Friction Drive in Beta testing (www.commuterbooster.com)
adrian_sm
Postby damonjackson_spl » Tue Feb 08, 2011 8:09 pm
SUPER!!!
cheers adrian, looking at 7.3nM, this beaing I found is 12.2nM, so just got to calculate using my gear ratio...
hmmmmm
damonjackson_spl
Postby liveforphysics » Tue Feb 08, 2011 8:18 pm
Also, keep in mind, Kt calculation ONLY depends on phase current, and you have no idea what your phase amps will be (with this motor, it's common to be 5x higher than battery current).
For ebike parts, don't be a douche, buy from http://www.ebikes.ca or http://www.MethTek.com
Justin saved the forum at great personal expense! The man is a legend and a hero!
liveforphysics
Postby dontsendbubbamail » Wed Feb 09, 2011 7:02 pm
damonjackson_spl wrote:I am ordering my the one way bearings for my single stage reduction..
cheers
D
How about a link to the bearing you found?
Bubba
dontsendbubbamail
Postby damonjackson_spl » Wed Feb 23, 2011 7:03 pm
dontsendbubbamail wrote:How about a link to the bearing you found?
Bubba
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=130293315445&ssPageName=STRK:MEWNX:IT
damonjackson_spl
Postby Miles » Thu Feb 24, 2011 4:51 am
Drawn cup roller clutch specifications:
TNSK_CAT_E1420_Drawn Cup Needle Roller Clutches.pdf
(1.94 MiB) Downloaded 63 times
Miles
Postby adrian_sm » Thu Feb 24, 2011 4:59 am
:lol: Check out the list of main applications on page 3.
(33.17 KiB) Downloaded 164 times
adrian_sm
Postby Miles » Thu Feb 24, 2011 5:01 am
Miles
Postby dontsendbubbamail » Thu Feb 24, 2011 9:10 pm
The clutch that you found needs to run on a hardened shaft and the motor shaft on the 80-100 is not hardened. Several years ago I looked at this type of clutch, but they did not calculate out to be strong enough for a single stage system. I not a mech eng so maybe I calculated wrong.
Bubba
dontsendbubbamail
Postby damonjackson_spl » Thu Feb 24, 2011 9:59 pm
dontsendbubbamail wrote:The clutch that you found needs to run on a hardened shaft and the motor shaft on the 80-100 is not hardened. Several years ago I looked at this type of clutch, but they did not calculate out to be strong enough for a single stage system. I not a mech eng so maybe I calculated wrong.
Bubba
The one way bearing is going onto my 44t pulley which is 6mm which ill lathe out to press in the bearing and installed on a hardened 12mm shaft
damonjackson_spl
Postby mainsource » Fri Feb 25, 2011 3:58 am
i have ordered the exact same motor but it has not yet arrived... what is the drive shaft diameter? what is the belt width, series-model and teeth counts of the timing belt pulleys that you are running? do you have a link to the source of the pulleys?
cheers, keith.
mainsource
Postby damonjackson_spl » Fri Feb 25, 2011 5:21 pm
I think most of the US lads use mcmaster for pulleys.
Im in aus so I used eBay.
I used T5 16mm pulleys and belts all 6mm id so I can lathe them out to either 12mm for the shaft or 18mm for the clutch. my bro is a fitter and turner and said hollowing out a 15t pulley to 12mm is probably the max u can go!! For the other pulley go 60t, I went 44t cause that is all the seller had in 16mm width.
damonjackson_spl
Postby mainsource » Sat Feb 26, 2011 2:05 am
thanks for the very useful info... am in Canada but i should still be able to access mc master karr (presumably thats the company to which you refer?)... did you actually turn the 15T to accept 12mm yet?,, did it turn out ok (regarding room for set screws etc)?
cheers...
mainsource
Postby Jeremy Harris » Sat Feb 26, 2011 2:43 am
For pulleys in the US/Canada I think you're probably best using SDP/SI: http://sdp-si.com/ as they seem to have far and away the biggest selection. Even my local supplier here in the UK seems to just stock the SDP/SI range.
The best pulley type, in terms of size for a given torque rating, seems to be the HTD series, or maybe the Gates GT2 series, rather than the older rectangular tooth T series used for timing belts. I've used 5M series belts and also the smaller 3M series for some lower power applications and they seem more efficient and transmit more power than the T series belts.
Jeremy
Jeremy Harris
Postby Miles » Sat Feb 26, 2011 2:45 am
mainsource wrote:am in Canada but i should still be able to access mc master karr (presumably thats the company to which you refer?)... did you actually turn the 15T to accept 12mm yet?,, did it turn out ok (regarding room for set screws etc)?
http://www.sdp-si.com/ and http://www.pfeiferindustries.com/custom_design.htm are good sources for drive parts.
You want GT2 or GT3 5M (8M if used for the final stage).
If you drill out 15t to 12mm bore, you may have to drill and tap new set screw holes through the teeth.
Ed. Jeremy beat me to it :)
Miles
Postby damonjackson_spl » Sat Feb 26, 2011 6:17 am
Yeah I keen to see how the T series go. regarding the 15t I'm getting my bro to check it out. I think he was going to press the pulley on and use locktite but he did ask the torque rating if the motor so he can calculate how to tackle the job.
I like having him around as real technical experience trumps academic speculation which I get into trouble allot for.
damonjackson_spl
Postby mainsource » Sun Feb 27, 2011 12:16 am
Fabulous website guys... and not just for pulleys... Whats a typical belt width for the 1st stage of motor speed reduction (drive motor to jack-shaft)?
mainsource
Postby dontsendbubbamail » Wed Mar 02, 2011 1:25 pm
mainsource wrote:Fabulous website guys... and not just for pulleys... Whats a typical belt width for the 1st stage of motor speed reduction (drive motor to jack-shaft)?
15mm
Bubba
dontsendbubbamail
Who is online
Users browsing this forum: No registered users and 6 guests
