Very cool.
You are my hero.
Matt
No Matt.
You are my hero and a lot of other people's. You carved the path for the rest of
us to follow, and you did it with competence and communicated it well. Thank
you from all of us.
Very cool.
You are my hero.
Matt
Miles wrote:I make it about 500 pounds on a 175mm crank....
No. 500 pounds at 175mm is equivalent to 400 newtons at 1 metre. So, you're not even halfway thereWhiplash wrote:Miles wrote:I make it about 500 pounds on a 175mm crank....
Do you mean that is what I am putting to the crank at 195lbs on the pedal? Basically that was what I am saying, the 400Nm is way less than I could do with body weight alone, right? Or no?
So on a sprocket with a 3 inch radius, that is a lot of force?
About 1166 pounds.............
Miles wrote:Max. power out is at half no-load speed.
Kv for the 3210 10t is 135rpm/V
Users browsing this forum: Miles and 6 guests
