StudEbiker's E-Bike-E build- ride vid pg. 7.
Re: StudEbiker's E-Bike-E build thread.
Postby Rassy » Fri Sep 23, 2011 1:10 pm
Great to hear you got it going. Looking forward to the full report on how it performs.
I guess when I was over in Ashland a few months ago and told you I was expecting to see it running I was just a little ahead of time! :D
-Rassy-
Two Tadpole Trikes, 6X10 9C mid drive, NuVinci CVT Auto Shift, 48V LiFePO4
viewtopic.php?f=28&t=18606
viewtopic.php?f=28&t=47043
Rassy
Postby Whiplash » Fri Sep 23, 2011 2:41 pm
Cool build! How many watts are you actually pushing through it? I have a 24V 400 brushed motor/controller I want to try using on a bike just for fun through the gears..
Power is a fascinating thing, the more you have, the more you want, but the real power is having the restraint not to use it all at once...............Um...Yeah..
The harder you work.....The luckier you get!!
"People who say it can't be done are often interrupted by those that have already figured out how to do it!"
Email me @ currentcycles@gmail.com
OR check out http://www.CurrentCycles.net
Whiplash
Postby dbaker » Fri Sep 23, 2011 2:43 pm
What speed are you getting? How much noise from the drive/motor?
dbaker
Postby StudEbiker » Fri Sep 23, 2011 7:48 pm
Peak watts today was 1400, but that's more than I had planed. The controller is pulling 40 amps and I had ordered a 30 amp controller. 40 amps is fun, and it will climb a wall, but that's not going to give me much range with my 10ah battery unless I can stay out of the throttle.
I had it up to 27 on flat level ground no pedal assist and I wasn't in top gear yet. I had planned for no faster than 30mph, so it looks like I got that pretty close.
It was a very warm day today and the motor got quite warm, but never so hot that I couldn't hold my hand on it. The controller got warm too, but not very.
As far as noise, the planetary makes the most noise I think. It's pretty loud, but not uncomfortably so.
There is an intermittent squealing sound that I'm not sure if it is coming from the planetary or a bearing. After it had been doing it for a little while I took the motor off the planetary. I have read there is an issue with the planetary rubbing the motor.
I had put a spacer, but I was concerned the spacer had not been thick enough and the squealing sound was the planetary rubbing the motor. After opening it up, it didn't look like it had been rubbing.
I decided to put some more grease in the planetary in case I hadn't put enough in the first attempt. Back out for a ride, the squeal was still there, but after riding for a little while longer it seemed to go away, so hopefully that was the issue.
Overall, I am extremely happy with the way it rides. I could use a larger front chainring to keep up with the jackshaft RPMs, but that is somewhat typical for builds like this I think.
I took it over one of the overpasses that I regularly cross. Unassisted, the TidalForce bike will do it at 14mph. Today I did it on the Bike E unassisted at 20mph. :)
TidalForce S-750-(build #2) w/9C rear w/EV Components Headway 36v 10ah LiFePo4 pack: http://endless-sphere.com/forums/viewtopic.php?f=6&t=15443&hilit=+headway+rack+pack
Bike-E (Build #3, mostly done)- 400W Kollmorgen mid-drive: http://endless-sphere.com/forums/viewtopic.php?f=28&t=25980#p375646
My Bike E Facebook group: http://www.facebook.com/groups/165756106813440/
"Facts do not cease to exist because they are ignored" - Aldous Huxley
StudEbiker
Postby StudEbiker » Sat Sep 24, 2011 10:50 am
I think I found out what the squealing was. :? The shaft moved in the bearings which let the #25 sprocket come in contact with the mounting plates. I don't think this is a major fail, but it was shifted so much that pedaling effort has gotten very hard and efficiency is in the toilet. I'm burning like more than an ah per mile. :cry: The next thing will be to add some spacers somewhere to keep the chain off of the plates.
The other bummer is that the gear hub is slipping. It's already not good and I know it will probably get worse. I may end up lacing the Nuvinci developer kit and trying it in the rear and see how that goes.
The bike is a real pleasure to ride though. So comfortable. And I have to say, having the extra weight of the battery and motor on it actually improves the ride of what it was originally. It is much quieter (when the motor isn't running) now going down the road.
There's just a few bugs to be worked out, but I still think this is going to be a good ride. I
StudEbiker
Postby dbaker » Sat Sep 24, 2011 11:39 am
How is the SA hub failing? Does it slip in all gears or just in 1st? What was your regular use pattern with the internal gear and the external casette/derraileur; how did you move through the gears?
dbaker
Postby StudEbiker » Sat Sep 24, 2011 11:45 am
dbaker wrote:How is the SA hub failing? Does it slip in all gears or just in 1st? What was your regular use pattern with the internal gear and the external casette/derraileur; how did you move through the gears?
It is slipping in all gears, but mostly in overdrive. I never rode this bike much before putting the motor on it. Only about 60 miles. The bike was poorly maintained before I got it. I have not shifted under power if that is what you are asking. I may have shifted once or twice yesterday under slight power just because I was getting use to the new drive and getting e coordination of it down. I have tried adjusting the shift cable and it doesn't seem to make a difference. I read on one site that one way to test if it is the hub slipping or poor cable adjustment is to take the cable off. It will default into overdrive then you can ride and see if the slipping is still there. If it is, it's the hub, if it's not, it's the cable adjustment. I guess I will try that out, but first I have to get the #25 chain off of the plates.
StudEbiker
Postby Gordo » Sat Sep 24, 2011 12:09 pm
Maybe put some thin teflon washers between the sprockets and the plates? Even scrap poly plastic from bleach bottles etc can be effective friction reducers.
X-treme 3KW Scooter...OFF ROAD ONLY....Giant 1KW 48V 24" Hubmotor....E-Apex 1KW 48V 26" Hubmotor, built 2012-05-26
Thanks Justin, for saving ES. May Grin Tech grow and prosper.
Gordo
Postby StudEbiker » Sat Sep 24, 2011 12:17 pm
Yeah, I'm gonna try Teflon washers first. Thanks for the tip.
StudEbiker
Postby StudEbiker » Sat Sep 24, 2011 1:08 pm
Well, I just started pulling things apart to put a spacer on the shaft and I see that one of the bearings is trashed too. So maybe that was the squealing sound. Nothing worthwhile is easy right?? :roll:
StudEbiker
Postby LI-ghtcycle » Sat Sep 24, 2011 9:22 pm
Glad to hear you have it up and running, I got my motor finally, but you definitely got yours going first! :mrgreen:
Hope the bearing is easily replaceable, if that is all the trouble you have, maybe you just need a heavier duty one and then you're set?
Sounds like it should be working well for you soon, and I'd love to see some pics once you can.
That trashed bearing would definitely take away your efficiency, so here's to hoping that is all you need to fix the problem. 8)
Thank you Justin_Le for your selfless act of kindness! We all are in your debt.
My latest build: Vision R40 with Golden Motor "800W" Trike motor as mid-drive, NuVinci N171B rear wheel as transmission, 30 MPH on 12S (46V) 12 AH Turnigy Nanotech LiPo (25-50c) able to climb tall hills on a single Amp Hour! :grin:
http://www.endless-sphere.com/forums/viewtopic.php?f=3&t=29810&p=475990#p475990
LI-ghtcycle
1.21 GW
1.21 GW
Postby StudEbiker » Sat Sep 24, 2011 9:59 pm
Thanks LI-ghtcycle, but I'm afraid with the slipping gear hub, there's more to be fixed than just replacing a bearing. :( I'm bummed but not down. Of course I would have liked for it to have worked perfect the first time, but such is life as they say. I still have to check to see if it is a chain slipping somewhere, or the gear hub. I suppose if it's the gear hub, I'll end up putting an S-A 3x9 in it, but that means having it laced in a rim which means more money and longer before I get it on the road. The good news is that while it was running right, it was incredible. Keep on keepin' on as they say. :P
StudEbiker
Postby Gordo » Sun Sep 25, 2011 12:46 pm
StudEbiker wrote:Thanks LI-ghtcycle, but I'm afraid with the slipping gear hub, there's more to be fixed than just replacing a bearing. :( I'm bummed but not down. Of course I would have liked for it to have worked perfect the first time, but such is life as they say. I still have to check to see if it is a chain slipping somewhere, or the gear hub. I suppose if it's the gear hub, I'll end up putting an S-A 3x9 in it, but that means having it laced in a rim which means more money and longer before I get it on the road. The good news is that while it was running right, it was incredible. Keep on keepin' on as they say. :P
You have built a beautiful, light, compact reduction which many can use to keep an RC type motor running in the sweet spot. I am sure it is disappointing for it to not be 100% perfect on the first try. Rest assured that companies spent 1000's of $$ on similar engineered designs which turn out to be totally useless because they can't even find a bearing which will take the load they have miscalculated to exist.
Did you try the suggestion of using a freezer and heated components for assemble. This is very good, valid advice. I have used it on everything from PS pumps to ring gears on flywheels. No beating the bearings to death is needed.
Don't expect a geared hub be happy with 10X it's intended input.
Maybe try a single speed as proof of concept and go from there?
Gordo
Postby StudEbiker » Sun Sep 25, 2011 1:13 pm
Gordo wrote:You have built a beautiful, light, compact reduction which many can use to keep an RC type motor running in the sweet spot. I am sure it is disappointing for it to not be 100% perfect on the first try. Rest assured that companies spent 1000's of $$ on similar engineered designs which turn out to be totally useless because they can't even find a bearing which will take the load they have miscalculated to exist.
Thank you Gordo.
Yeah, I turned the shaft down in a drill press using emery cloth, and cooled the shaft in ice before assembly, but the bearing has to go on the shaft for about 3" on the side that went defective and it just seemed like the shaft wasn't cold enough. As far as heating the bearing, the person I was working with was concerned that heating the bearing might make the OD smaller because of the expansion. At first I disagreed, but after thinking about it some, it did seem like that might occur. The metal would expand in all directions, not just outward so why wouldn't the OD get smaller? I also put flat surfaces on the inner and outer race of the bearing as I lightly tapped it on bracing the other side of the shaft. The best news though is the all the set screws have held so at least that issue is sorted out it looks like.
I am still holding out hope that there is just an adjustment on the 3x7 that isn't right. If I end up going with something else, I will either put an S-A 3x9 in it, or the Nuvinci developer kit with the automatic electric shift. The Nuvinci should be able to handle the power easily, but the Nuvinci will add more weight to the bike. It would be pretty awesome not having to shift though. :)
StudEbiker
Postby Gordo » Sun Sep 25, 2011 1:57 pm
You are 100% correct on heating a bearing makes the ID smaller. The trick is to heat a segment. A pie slice section of the bearing or any other cylindrical junction. I remember heating and beating my 30" boat propellor half to death over a 2 day period, after I bent the shaft from hitting a rock. An old fellow came along to investigate all the cursing and asked me if I had heated it? After confirming that I did not know what I was doing, he took the torch, heated a small area of the prop, to just hand warm and told me to hit it on the back side. Knowing this was a useless idea, I hit it a half-assed blow and it FELL OFF. :shock: My big problem with this knowledge, is no one will believe you, until they learn to just heat stuff a little bit, in a small section, before giving it a tap. I took a frozen bushing off a starter motor shaft, just a month ago, using this method. Heat a little on one side, and tap the shaft on a steel block. The bushing fell off.
Throw your shaft in the freezer for a couple of hours instead of ice. Colder is better.
If you ever get a chance at -50*F or C, take a hammer and strike a steel plate with it. Hard steel behaves like glass when the molecules are compacted enough.
Heat a small area of your bearing and quickly slip it home, on the cold shaft. You will be amazed.
Gordo
Postby StudEbiker » Sun Sep 25, 2011 2:14 pm
Good tips Gordo, thanks. What about using dry ice? A local store here sells it. Would that be too cold? How long should I put it on the dry ice before trying to put it through the bearing?
StudEbiker
Postby Gordo » Sun Sep 25, 2011 2:26 pm
Dry ice is not such a good idea as -100C can do unwanted (unknown by me) things to steel. Over kill too. Bush ape rule of thumb, you only need 0.001 interference per inch of diameter for a bearing. Readily available with home freezer to room temperature, especially if you us a heatgun/hair dryer on a segment of the bearing.
Gordo
Postby StudEbiker » Mon Oct 10, 2011 12:26 am
Well, the Sachs is out and the Nuvinci is in. Still waiting on replacement flange bearings. The first order got lost in the mail. :? I'm hoping to make some progress on Wednesday.
StudEbiker
Postby wineboyrider » Mon Oct 10, 2011 2:06 am
StudEbiker wrote:Well, the Sachs is out and the Nuvinci is in. Still waiting on replacement flange bearings. The first order got lost in the mail. :? I'm hoping to make some progress on Wednesday.
Pricey booger? What did she cost?
:lol:
wineboyrider
Re: StudEbiker's E-Bike-E build now w/Nuvinci
Postby StudEbiker » Mon Oct 10, 2011 9:41 am
It's one of the auto shifting developer kits that are being sold at close out for $149.99 plus shipping. :D
http://www.fallbrooktech.com/09_LEV_Kit.asp
StudEbiker
Postby wineboyrider » Mon Oct 10, 2011 3:07 pm
Wow that's pretty cool... wish I had the money I'd like to try one out, but builds are out for awhile now as I have to save $$$ for the old country. I am definitely looking forward to seeing how this one turns out...
8) 8) 8) 8) 8) 8)
wineboyrider
Postby StudEbiker » Wed Oct 12, 2011 10:53 pm
I had a chance to put the wheel in the Bike E today. It looks pretty good.
I'm not completely happy with the way the spokes are bending aroud each other, but this is how the guy at Nuvinci said that they were spoking these in 20" wheels. The wheel feels good, it just looks kinda weird.
I was concerned that the actuator housing wasn't going to have enough clearance for me to still be able to use my trailer mounts, but it looks like everything is going to clear fine.
StudEbiker
Postby amberwolf » Wed Oct 12, 2011 11:43 pm
Just don't forget to tie the actuator unit down to the frame snugly. ;) I almost forgot to plan for that when pondering my most recent scheme for the new bike. :lol:
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby StudEbiker » Wed Oct 12, 2011 11:48 pm
I tried to find a way to use that included bracket, but there wasn't any good way to use it. I will still need to come up with some sort of bracing for it I guess.
StudEbiker
Postby LI-ghtcycle » Thu Oct 13, 2011 1:12 am
Looks good man! :D
Don't forget to let us know how much efficiency you get using that bad boy!
LI-ghtcycle
1.21 GW
1.21 GW
PreviousNext
Who is online
Users browsing this forum: andyman, skyungjae and 12 guests
