That's certainly the way they were designed to be used. See: http://www.schlumpf.ch/hp/schlumpf/bild ... 1.engl.pdfbobc wrote:The teeth are that way round so that the bearing/loaded tooth surface is a full face contact on the sprocket - otherwise you'd surely wear little "hooks" on the belt teeth which wouldn't be nice..
Miles wrote:That's certainly the way they were designed to be used. See: http://www.schlumpf.ch/hp/schlumpf/bild ... 1.engl.pdfbobc wrote:The teeth are that way round so that the bearing/loaded tooth surface is a full face contact on the sprocket - otherwise you'd surely wear little "hooks" on the belt teeth which wouldn't be nice..
I've used 16t for 8M PowerGrip belts. It's possible that the tooth geometry or construction of the Carbon PolyChain belts would be more restricting, though. Obviously the capacity would be lower.jk1 wrote:What would be the smallest pulley teeth count you could use on the gates 8mm pitch carbon drive belts ? this is for a mid drive on the motor side.
In the data sheet i think 22teeth is the minimum, if i made a custom drive sprocket would it work for say an 16 or 18 teeth cog on the motor ? or would it slip, I am thinking of using the 10mm wide CARBON POLYCHAIN FOR a 3 to 4 kw motor would that work for such a small motor pulley ? would i have to use idler to increase the belt wrap ?
jk1 wrote:One thing that just occured to me can u get the carbon poly chain in small lengths ? i.e to suit mid drive or are they only made very long to replace normal bike chain ?
You could try with a "snubber" pulley first (engages only if the belt starts to rise on the teeth).jk1 wrote:would i have to use idler to increase the belt wrap ?
Users browsing this forum: stEVe and 15 guests
