Beta CA build for R/C controllers
Re: Beta CA build for R/C controllers
Postby Grinhill » Mon Aug 22, 2011 7:12 am
Thanks for the detailed info Kim.
I've got one of the new CAs but I'm yet to get mine wired up.
1995 Giant Hybrid - Zeta2 with 12V 7AH SLA - removed after one year.
2006 Converted Giant to Geared Brushless Rear Hub with 24V 17AH SLA - bike stolen 2007.
2008 Hardtail MTB Disc Brake - lightweight RC/LiPo system.
Grinhill's Medium-power RC-Motor Hardtail build
The Grinhill Mk2 RC-motor drive
Grinhill III - "Supercommuter" featuring Recumpence RC drive
Grinhill
Postby johnrobholmes » Mon Aug 22, 2011 10:15 am
Sounds awesome! Glad to hear you got it set up and handling very well 8)
_______________________
Volt up, gear down!
http://www.HolmesBikes.com -- Custom 15 -12ga spokes
http://www.VoltRiders.com -- Custom wheels, ebikes, and Mopeds
johnrobholmes
Postby Whiplash » Mon Aug 22, 2011 2:36 pm
Very cool to hear AJ! So, I am still a little confused about this setup, does it actually limit the current now? Or is it just that it gives better control over the throttle and makes it smoother? I guess I am wondering it if fixes the low RPM high load problems associated with the R/C speed controls?
Power is a fascinating thing, the more you have, the more you want, but the real power is having the restraint not to use it all at once...............Um...Yeah..
The harder you work.....The luckier you get!!
"People who say it can't be done are often interrupted by those that have already figured out how to do it!"
Email me @ currentcycles@gmail.com
OR check out http://www.CurrentCycles.net
Whiplash
Postby johnrobholmes » Mon Aug 22, 2011 2:46 pm
It limits battery side current and converts the R/C controllers into a current based throttle instead of a voltage based throttle.
It does not fix the low RPM loading issue with these controllers, as there is no phase current or RPM detection. I think it may have a feature where it does not run below a set RPM however, and that could get around the issue.
Volt up, gear down!
johnrobholmes
Postby adrian_sm » Mon Aug 22, 2011 4:38 pm
Hey Kim,
Great to hear the CA-LRC is working out so well on the cruiser.
I found it interesting that all the gain settings you settled on, appear to be the default ones that the CA-LRC ships with. This is great, since they are the ones that can require some tuning to set-up if you need to adjust them, the rest are relatively straight forward, measure/set/forget settings.
Hopefully this means that most people wont need to play around too much when setting up the CA-LRC, except for us "fairy friction" setup guys that have needed to tweak AGain to soften the response depending on the Amp Limit used.
- Adrian
AussieJester wrote:CA Settings
Amps Limit 130amp
Low Volts limit 39v
Main Display Watts
Set Range High (0.1A)
Averaging 5
Set RShunt .7000m0hm (using the two shunts combined as one, Justin Sent with CA)
Volt Sense 31.10V/V
PSGain 0.08V/kph <------ DEFAULT = 0.08
ISGain 200 <------------ DEFAULT = 200
AGain 300 <------------ DEFAULT = 300
VGain 800 <------------ DEFAULT = 800
ITerm Max 2.00mS
ITerm Min 1.21mS
Aux Thresh 0.75V
Vshutdown 10V
Build #1 ~28kg ~ 700w Avanti Hardtail Crystalyte 408, 48V10Ah Headway. ~5500 kms to date. (retired)
Build #2 ~30kg ~2000w Giant AC Dually Crystalyte 408, 48V10Ah Headway + 6s10Ah LiPo = 70V. ~15000 kms to date [SOLD]
Build #3 ~13kg ~2000w Commuter Booster <1kg Friction Drive in Beta testing (www.commuterbooster.com)
adrian_sm
Postby AussieJester » Mon Aug 22, 2011 4:44 pm
Whiplash wrote:Very cool to hear AJ! So, I am still a little confused about this setup, does it actually limit the current now? Or is it just that it gives better control over the throttle and makes it smoother? I guess I am wondering it if fixes the low RPM high load problems associated with the R/C speed controls?
There is a setting to limit current, and according to the Castle Creation data logging, it is spot on the money too, I have mine set for 130 amp it limits the fun factor with the right hand, the CC hv160 spikes a 100amps+ when its inboard current is set to lowest 160amp setting, I guess I am pretty unobservent too, as aside from when the rear wheel is off the ground and the throttle is held steady (the power keeps rising when motors unloaded) i don't notice any difference from a voltage based throttle when actually ridding the bike, I don't even notice the current limiting kicking in, the only negative is the settings and understanding what they do and how much each affects throttle response, other than this its an outstanding piece of kit!! Once a few more of the well respected members ac actually try these, and report back with their findings, these rc CAs will be HUGELY popular.
KiM
Hahaha@adrian I knew that one of u friction bois would bite. I did forget to add my CC hv160 throttle setting is on 3. My magura pot has also been adjusted from stock, see previous page for easy how-to and what ca setting requires changing to match.
KiM
AussieJester
Postby justin_le » Mon Aug 22, 2011 6:06 pm
johnrobholmes wrote:Well it certainly sounds like there are as many opinions on throttle control as there are people in here :lol:
Voltage based
amperage based
mixed control
Any way to have each type selectable on this Justin?
For sure anything can be done in principle! Just trade-off's to consider with development time and having too many options / parameters which can cause more confusion than it is worth. Plus trying to figure out if we can squeeze all of this in the standard CA code or vs. needing to have a separate firmware specific to RC applications.
Right now it is possible to select between current throttle or an actual speed throttle, and I'm working on having a 'throttle pass-through' option to effectively achieve a voltage throttle as most people are familiar with. Out of curiosity, has anyone here with an R/C CA tried setting it up as a speed throttle mode?
You just need to set AuxVoltage to Speed Limit to achieve this, and set your Speed Limit to something reasonable. I have a feeling that without a proper damping term in the PID loop that people will have a hard time getting it to hold steady without a fair bit of overshoot and undershoot, but I would be interested to hear if anyone has experimented with it.
-Justin
Big Dummy with 24" eZee front hub, 25A infineon controller, and 48V 10Ah LiMn pack
My website: www.ebikes.ca
Please contact via email, info@ebikes.ca, rather than PMs
justin_le
Postby AussieJester » Mon Aug 22, 2011 6:30 pm
When you say "set the speed limit to something reasonable" What exactly is ' reasonable' Justin? As I think my idea of ' reasonable speed limit' might differ a fair bit, I cam try it right now if you clarify this for me buddy!
KiM
AussieJester
Postby johnrobholmes » Mon Aug 22, 2011 7:11 pm
So the RC CA can use speed mode for throttle too? Probably solves my want right there. Like a voltage throttle and then some, the automatic torque mode!
I am setting up a DPDT switch on my normal CA so that I can swap between amperage and voltage control. Both have advantages and disadvantages. I can tell you I hate the amperage throttle when I am riding with a group, absolutely do not like it. It is so much harder to keep constant speed and ride with a pack, it is like I am always hunting for the load of the road. The differences in terrain are much more pronounced with the amp based throttle. I haven't used current mode in a while for this reason, as I routinely ride with many other bikes. It just takes more throttle action than I am used to, even if the power control is better when the cards are all on the table.
On the other hand when I ride by myself I really enjoy the amp throttle. When I joyride I typically cruise at low speeds so I can double my range and enjoy the ride. Totally easy to keep a low amp draw or dial it down with a POT in amp mode and not even worry about the load that the upcoming hill will put on my pack. Furthermore it gives instant feedback on the power being used, no more glancing down at the CA display as I go up the hill to keep track of amps.
But really we are splitting hairs here. Its funny that this is a main focus of the thread, and not just how awesome this product will be! Obviously the RC CA doesn't have far to go, or else there would be a lot more talk about how to improve it and what it lacks instead of the finer points of throttle control :lol:
Volt up, gear down!
johnrobholmes
Postby fechter » Mon Aug 22, 2011 7:41 pm
justin_le wrote:.... I have a feeling that without a proper damping term in the PID loop that people will have a hard time getting it to hold steady without a fair bit of overshoot and undershoot, but I would be interested to hear if anyone has experimented with it.
-Justin
I'm not sure how hard it would be to test, but I thorize that having a fast attack, slow decay in the feedback loop can prevent a lot of the oscillation issues without sacraficing safety. Of course practice never seems to cooperate with theory.
Another more difficult approach is to use a feed forward arrangement to minimize overshoot. You have to sort of predict where the PWM needs to be in the near future based on input changes, error, and rates of change.
fechter
Postby justin_le » Mon Aug 22, 2011 7:43 pm
johnrobholmes wrote:So the RC CA can use speed mode for throttle too? Probably solves my want right there. Like a voltage throttle and then some, the automatic torque mode!
Indeed. Just be warned that it might be a speed mode akin to being towed at constant speed via a bungee cord :wink:
I am setting up a DPDT switch on my normal CA so that I can swap between amperage and voltage control. Both have advantages and disadvantages. I can tell you I hate the amperage throttle when I am riding with a group, absolutely do not like it. It is so much harder to keep constant speed and ride with a pack....
... On the other hand when I ride by myself I really enjoy the amp throttle. When I joyride I typically cruise at low speeds so I can double my range and enjoy the ride. Totally easy to keep a low amp draw or dial it down with a POT in amp mode and not even worry about the load that the upcoming hill will put on my pack...
That's a great summary of the difference and merits of each approach. If you have a voltage throttle but are trying to keep an eye on your battery consumption, then you are always tweaking the throttle up and down with every change in terrain which is a PITA, while a current throttle lets you hold steady in the same place. However, if you are mostly concerned about keeping a steady speed, then a current throttle requires endless tweaking based on the terrain while a voltage throttle can just be held in place.
Anyone else trying to understand the 'implication' of a current vs. a voltage throttle in practice, that is it.
For someone interested in control loops and human interfaces to EV's, these are exciting finer points to hear about and see actively discussed though!
justin_le
Postby justin_le » Mon Aug 22, 2011 7:54 pm
-Justin
That's exactly what a differential term would do. If it senses that the vehicle is accelerating even if it is still below the target speed, it will preemptively start to back off on the PWM output. It's actually quite simple to code as well, and would result in very smooth speed control, but it requires that the CA have an accurate value for the instantaneous acceleration which isn't implemented in the base code yet.
justin_le
Postby amberwolf » Mon Aug 22, 2011 8:02 pm
This is a bit OT, but:
Justin, could you take a peek over here and let me know if that control method, using the CA, would work for the NuVinci gear change?
viewtopic.php?f=28&t=30641&p=451734#p451734
If it would, that would be an awesome way to deal with the control of the NV, and not have to add any (or much) other electronics to the bike than I already have. :)
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby johnrobholmes » Mon Aug 22, 2011 8:20 pm
justin_le wrote:For someone interested in control loops and human interfaces to EV's, these are exciting finer points to hear about and see actively discussed though!
I wish I had more people interested in this near to me. I can't really tell my girlfriend how my day went when it involves the finer points of controlling a PWM based system :lol:
Glad to be a part of the discussion, if I can help in the development otherwise just let me know.
Volt up, gear down!
johnrobholmes
Postby Arlo1 » Mon Aug 22, 2011 11:22 pm
Yup same here. Just remember if they don't find ya handsome at least they find ya handy, were all in this together :)
Thanks Justin of http://www.ebikes.ca/
Also a thanks to Methy at http://www.methtek.com/ :)
And Dave who has some good deals on STUF
RC lipo and most other types of Lithium batteries you MUST know your individual cell voltages while charging and discharging.
Batteries of all kinds need respect they can burn your house down, so don't sleep with them under your bed or any other were you cant afford smoke or fire!
[color=#FF0000][b][size=150]Never above 4.2v never below 2.7v EVER!!!
Arlo1
Postby johnrobholmes » Tue Aug 23, 2011 9:09 am
While we are on the subject of interfaces...
Are there any extra channels on the CA that could have temp inputs, like 10k thermistors?
Volt up, gear down!
johnrobholmes
Postby nicobie » Tue Aug 23, 2011 1:32 pm
Now you're talking!
I'd love to see a temp monitor function on the CA.
May your tote always stay tight and your edge eversharp :wink:
my eTownie build thread: viewtopic.php?f=6&t=23701
nicobie
Postby Whiplash » Tue Aug 23, 2011 2:33 pm
That is a GOOD Idea!
Whiplash
Postby Kepler » Sat Sep 03, 2011 11:34 pm
I have converted one of my K-force 100A esc's for direct connection to the CA. It gets a bit tight soldering the shunt directly to the ESC circuit board as Justin did with the CC160 esc so I decided to fit the shunt half way along neg cable.
Couple of other minor differences to what Justin did with the CC160.
The yellow +5V form the CA has been cut back and isn't used as the K-force has its own +5V supply.
I havent looped in the Grd from the CA to the ESC control wire Grd as they are grounded within the ESC anyway.
I only used one of the supplied shunts rather then paralleling 2 shunts together. This setup will only be used at around 30A and I figure one shunt should be fine up to 50A without a problem. This means the CA shunt value will be set to 1.4 mohm.
I havent had a chance to test it yet with this setup as I sold my CA with a drive last week but should have a batch arriving in a week or 2 so I can give it a test then.
Current Rides
Carbon Super Commuter: ON ROAD http://endless-sphere.com/forums/viewtopic.php?f=6&t=47139
eBoost on facebook: http://www.facebook.com/pages/Eboost/200306283342024/
75 Volt 2.5 kW Stealth Fighter: OFF ROAD http://www.stealthelectricbikes.com/
Kepler
Postby AussieJester » Sun Sep 04, 2011 12:12 am
Kepler wrote:This setup will only be used at around 30A and I figure one shunt should be fine up to 50A without a problem. This means the CA shunt value will be set to 1.4 mohm.
Can confirm, for at least breif periods, those shunts can handle over 160amp without turning to molten metal LoL...only breifly mind you..
How are you finding the rc CA now you have had some more time to 'play' with it Keplerz ma main MAN? :wink:
Personally just liking it more and more each time i ride power delivery is silky smooth and if you rip the throttle hard A HELLA lota fun talk mega ev-grin....Have her cranked to 160amp now cuts off smack on the mark too god bless Justin Le godanm rock star he is!!!
KiM
AussieJester
Postby Kepler » Sun Sep 04, 2011 1:30 am
Excellent. Sounds like the single shunt will suit my application just fine.
Been really pleased with how the RC CA has worked out. I am now offering it as an option for my drives as its worked out to be a really easy plug and play fit. The button throttle setup works really well too so now I have basically all throttle options covered. Just ordered another 5 units with the view to install a few more in some of my drives and also to have some local stock handy for re sale.
Current Rides
Kepler
Postby hjoore » Fri Sep 16, 2011 5:31 am
Hey Justin,
I just ordered a CA-LRC too for my mini friction drive system, are they still in production or is it just the test batch?
Is there a way to limit the maximum speed as well? Cause then my friction drive would be 100% legal in the Netherlands!
Thanks, hjoore
hjoore
Postby AussieJester » Fri Sep 16, 2011 6:13 pm
hjoore wrote:Hey Justin,
Thanks, hjoore
I do believe there is ;-)
KiM
AussieJester
Postby Bluefang » Mon Nov 07, 2011 2:17 am
With this CA is it possible to run more then one motor and controller while still been able to limit the current to the motors. Or would you have to take the sum of all the amps going to the controllers and limit that max and pray that all the controllers draw the same current?
This would have all the motors on a single shaft, say 4 Turnigy 80-100 motors with 4 castle HV160. I don't suppose there would be a way to limit each controller separately? Or would i have to buy a CA for each controller that way and run everything from one throttle? And a question for those running multiple motors do they ever have a large difference in the power each motor provides seeing as they are mechanically linked?
viewtopic.php?f=10&t=49912 Current build, Electric flat tracker
Bluefang
Postby Grinhill » Mon Nov 21, 2011 6:58 am
Sorry for the belated beta-testing report, but I finally got around to running my CA-LRC last week on my Hunter EV Prize race bike.
( Hunter Valley EV Prize thread). I just used a single shunt.
Worked beautifully first go. I plugged in similar numbers to Adrian, and basically ran with that in the race. I really only had five laps of practice, so I didn't change any parameters before the race.
I probably should have slowed the response a little since the race was a test of battery life. I found it was fairly quick to get to max power and fairly quick to back off as well.
Top work Justin, thanks heaps!
Grinhill
PreviousNext
Who is online
Users browsing this forum: Idontwanttopedal, Sten and 8 guests
