Luke's commuter bicycle. What Non-hub is all about.
Re: Luke's commuter bicycle. What Non-hub is all about.
Postby Thud » Wed Dec 14, 2011 8:27 pm
RWP,
I am pretty certain they grabbed an off the shelf rotary encoder for reading position. a quick google brings up several that could be employed with a little creativity:
http://www.quantumdev.com/products/opti ... /sc12.html
http://ab.rockwellautomation.com/Motion ... te-Encoder
No idea which brand or model is employed....or even if its a production pc or a modded one. These guys have acces to a wide range of specialty/odd ball motor controller stuff that we can only dream about & the ability to mod existing stuff to fit the bill.
Luke has a great team of inovators to tap for help on these things.
get some......
Thud
Postby bigmoose » Wed Dec 14, 2011 8:30 pm
Two nice things about the sin/cos sensor:
  • It get the position sensing element out of the stator heat flux
  • It allows precise timing advance with the right controller just like a timing map in an IC ECM
bigMoose's electronic pieces & parts (GENUINE IRFB4110Pbf's, Nomex 410, AntiCorrosion Grease, Current Sensors) available HERE.
Thanks to Justin ebikes.ca for securing the board then setting us FREE! Tech Tips in the WiKi: http://endless-sphere.com/w
"Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God..." all the best, Dave
bigmoose
Postby Thud » Wed Dec 14, 2011 8:32 pm
I rest my case. :wink:
get some......
Thud
Postby John in CR » Wed Dec 14, 2011 8:36 pm
Congrats on the quickest ebike on the planet!
I don't care much about top speed it's that quickness that I want up to say 50mph or so. What was the weight all up with your pilot in the video, and geared for what top speed, so I can figure out how much power I need to accelerate somewhere close to that quickly?
It sounds like you have it really dialed in now. Have you tried regen yet? Mild regen sure is sweet with a ride-around bike.
John
John in CR
Postby kfong » Wed Dec 14, 2011 8:37 pm
Not knowing much about the sevcon's I can only assume the controller has inputs for such sensors. For us with less access, there was discussion a while back on optical sensors to function as hall sensors. The whole point, is to move the heat sensitive stuff out of the motor and into an area that is less harsh. I believe Bertie had some success doing this. With the sine/cosines stuff the resolution is really good though.
kfong
Postby geetarboy » Wed Dec 14, 2011 8:48 pm
God! What a fun looking ride, Great work Luke!
geetarboy
Postby liveforphysics » Wed Dec 14, 2011 9:10 pm
bigmoose wrote:Two nice things about the sin/cos sensor:
Yes sir it does. We did it mainly for the heat reason you mentioned, as hall melting failure was our demise at the last race event, as well as a previous race.
The second reason you mentioned wasn't really something we were needing for this application, but WOW! It just make it silky smooth, no more chug-chug-chug at low RPM's as each hall sensor latches and tells the fets to switch the next coil on, it's just silky now, you can make the motor spin so slowly you can barely see it moving at all, and it's just perfectly smooth with no torque ripple noticed at all now. Really feels like electric power should feel at all RPM's rather than little bumps of torque pulses when you're at low speeds.
It's fun having this much torque too, I just nosed the front wheel up to a staircase outside a strip mall, and in a very slow controlled calm way, just torqued up the 10 stairs or so and rode along the sidewalk path at the top. It felt even easier than walking up stairs, though the seat does kinda smash into your ass as the rear tire goes over each step. I don't know that it would have been possible to do it so effortlessly on hall sensors.
For ebike parts, don't be a douche, buy from http://www.ebikes.ca or http://www.MethTek.com
Justin saved the forum at great personal expense! The man is a legend and a hero!
liveforphysics
Postby flathill » Wed Dec 14, 2011 9:32 pm
Damn that is quick! Like sub 4 second 0-55mph?
Now you just need to sell the Sevcon pre programmed for this motor or give the code away to electricmotorsport and thunderstruck :D
Could probably get away with the smaller Sevcon gen4 and I'm guessing the same settings would work, no?
flathill
Postby boostjuice » Wed Dec 14, 2011 9:57 pm
liveforphysics wrote:
This motor fitted with external sine/cosine rotor position encoder:
http://www.goldenmotor.com/HPM-10KW%203D.jpg
Which motor wind did you select Luke? the "48V", "72V" or "120V" option?
And likewise with 'flathill', acceleration numbers would be great to know :mrgreen:
boostjuice
Postby dirkme » Wed Dec 14, 2011 10:15 pm
Okay, I trust you understand that this illegal and mean ;-) therefore you got to pack that ebike in a good box and send it over to me :-)) Now!
dirkme
Postby amberwolf » Wed Dec 14, 2011 11:05 pm
Pardon the lightly OT:
liveforphysics wrote:A bicycle worthy of my commute.
The video text says that Ryan added a sin/cos encoder...does this encoder translate into the typical 3-hall signal output, or does it just go into the controller itself as sin/cos instead? (I would bet the latter but am hoping for the former)
I'd be interested in details on it if it is the former (but I don't have a controller that uses the latter yet), as I'd like to build something like that to run that powerchair motor
viewtopic.php?p=503510#p503510
on one of my existing ebike controllers, using the existing sin/cos sensors in the motor.
RWP wrote:What is a sine/cosine rotor position encoder?
How does it work? Can a mere mortal make one?
I like pictures :lol:
Another motor's built-in sin/cos sensor and magnet ring, also kept away from the potentially hot stator and magnets:
viewtopic.php?p=486263#p486263
The sensors themselves:
The magnetic encoder ring, mounted on the axle spindle-to-wheel-hub interface:
The output of such a sensor looks like this:
House Fire Updates Thread
DayGlo Avenger, MkII
amberwolf
Postby Alan B » Wed Dec 14, 2011 11:26 pm
Advanced motor controllers commonly have sin/cos encoder inputs. They resolve this into the precise angle of the motor rotor and drive the motor as needed. They use this to get the timing right, with dynamic timing advance, etc.
Alan B
1.21 GW
1.21 GW
Postby Arlo1 » Thu Dec 15, 2011 12:52 am
It is so so so exciting to be in the middle of all this EV stuff just taking off! And bigmoose you deserve so much for all your help, as do many others incl luke him self! I have never been so excited for something in my life. This whole thing is the reason I can't wait to get up and go see what I can learn on my computer in the morning! 2012 is going to be a HUGE year for extreamly fast ebikes!
Thanks Justin of http://www.ebikes.ca/
Also a thanks to Methy at http://www.methtek.com/ :)
And Dave who has some good deals on STUF
RC lipo and most other types of Lithium batteries you MUST know your individual cell voltages while charging and discharging.
Batteries of all kinds need respect they can burn your house down, so don't sleep with them under your bed or any other were you cant afford smoke or fire!
[color=#FF0000][b][size=150]Never above 4.2v never below 2.7v EVER!!!
Arlo1
Postby liveforphysics » Thu Dec 15, 2011 2:05 am
Amber- It directly takes the Sine/Cosine input from the encoder. I think it's good to 0.25deg rotor position if I'm not mistaken. The halls were good to 6deg resolution (10 poles, 3 halls on 120deg spacing)
I think only Ricky's amazing DIY controller would be capable of greater than this degree of rotor position, but it sure costs a hell of a lot more in dedicated fast A2D's than it costs to mount a $50 encoder and run 4 wires.
liveforphysics
Postby RWP » Thu Dec 15, 2011 2:22 am
I found some individual encoder chips on line.
Is it a trivial thing to mount them like we do hall's, or is this not possible?
OH...a $50 encoder...good enough!
My electric vehicle projects Home of the eTownie & eCortina
Cortina V3 Turnigy 80x - HV 160 - 48v 15Ah
Cortina Revisited Turnigy 80x - HV 160 - 48v 15Ah
Cortina Hard Tail Build Cortina Triton DS - eFlite 160 - 36v 10Ah LiPo - TURNIGY K-Force 120A-HV - Nexus 3 speed internal hub
RWP
Postby liveforphysics » Thu Dec 15, 2011 2:27 am
RWP wrote:I found some individual encoder chips on line.
You gotta drill a pocket into the back of the motor shaft for the encoder magnet to get glued in. Then just some structure you can afix the encoder package to sit over that magnet. Then you need to clock the encoder to be aligned properly, which requires an o-scope tinkering. Then you make sure you've got which is which for sine/cosine sorted out, send that to the sevcon's encoder input, and you're ready to begin configuring the sensor to the controller and start dyno tuning.
liveforphysics
Postby Kiwi » Thu Dec 15, 2011 2:31 am
have you got a NZ guy working with you, thought I caught a kiwi accent in the video?
Its great to see an electric bike with some power that doesn't leave you yawning.
Nice work.
Kiwi
Postby RWP » Thu Dec 15, 2011 2:41 am
Thanks Luke - You da MAN for your manly bike!!! :mrgreen:
OK then...is the encoder signal anything like a hall signal that would connect to a controller that is more common to what we are currently using?
Guess I am trying to find a way for a mere mortal to do this :roll:
RWP
Postby amberwolf » Thu Dec 15, 2011 3:39 am
RWP wrote:OK then...is the encoder signal anything like a hall signal that would connect to a controller that is more common to what we are currently using?
No, not if you're talking about common ebike controllers like the Infineon/Lyen/Crystalyte/Ecrazyman/XieChang stuff; that's the problem I am asking about in my post on the previous page and in my powerchair thread. ;)
You'd have to convert the sin/cos into the hall-per-phase types those are expecting. Can be done with either analog electronics or with an MCU and some programming, but it won't give you the resolving power of directly using the sin/cos signals, AFAIK--you're still limited to whatever the controller itself accepts for input. It does let you use encoding outside the hot motor, at least (but really, you could do that with the regular halls, too, if you add a second set of magnets just for the halls to detect. Or you could use optical sensors to do the same job the halls did, and a light/dark ring in the pattern of the magnets).
amberwolf
Postby Spacey » Thu Dec 15, 2011 4:08 am
Luke that bike is awesome, damn your making me want to get rid of my frock motor on my Greyborg now lol
Spacey
Postby jingles98 » Thu Dec 15, 2011 4:39 am
I think we've all updated our Christmas list for one of these bikes Luke. Like i said before mate, you are a God.
jingles98
Postby gensem » Thu Dec 15, 2011 9:32 am
How much thrust this thing puts on the ground?
300 pounds?
A decent 25mph bike will cost around $1000.
A decent 35mph bike will cost around $2000.
A $1000 35mph bike will get you killed.
Justin we really appreciate what you did!
gensem
Postby Jozzer » Thu Dec 15, 2011 12:22 pm
:mrgreen:
Mazda MX-5. 300KW power. Soliton 1 controller, 11" Kostov motor, 20KW/H Turnigy Lipo for 60-100 miles range. 120mph top speed.
Hudson Kindred Spirit 3 wheeler. Twin Agni setup, 300KG 80KW. 100mph top speed (maybe more, but no-one has the guts to try!)
Aprilia RS125, Agni motor, 600A 96v Kelly controller, 6kw/h Turnigy pack.
www.Jozztek.com
Jozzer
Postby liveforphysics » Thu Dec 15, 2011 12:27 pm
Jozzer wrote::mrgreen:
Thanks Jozz. I always value you work and input.
liveforphysics
Postby Whiplash » Thu Dec 15, 2011 3:23 pm
Hey Luke,
just a crazy question, what would you need to get to setup a drive system like this, say if one of us sent you the motor/controller and had you set it up similarly? I would LOVE to build a frame and just be able to slap a drive into it like this!!
Power is a fascinating thing, the more you have, the more you want, but the real power is having the restraint not to use it all at once...............Um...Yeah..
The harder you work.....The luckier you get!!
"People who say it can't be done are often interrupted by those that have already figured out how to do it!"
Email me @ currentcycles@gmail.com
OR check out http://www.CurrentCycles.net
Whiplash
PreviousNext
Who is online
Users browsing this forum: Doctorbass and 9 guests
