Whiplash wrote:Wont those bare open ears present a problem?
hotschott wrote:Hi,
I've made a stand up scooter powered by a 80/100/180 my controller is a dlux 160 and I recommend to add capacitors if you lengthen the battery wires. I've 7km and it seems to work well. Don't try to start from standstill or it will burn.
Andje wrote:There is lots of info on here about RC motor rewinding, and plenty more on RC forums. It is reportedly a blistery hassle, but you can substantially increase the reliability of that motor as well as repair at the same time.
I love the direct geared tranny; that is one of only two or three geared bikes on the sphere. Good luck with the rest of your project! We are all rooting for you!
silvocross wrote:Andje wrote:There is lots of info on here about RC motor rewinding, and plenty more on RC forums. It is reportedly a blistery hassle, but you can substantially increase the reliability of that motor as well as repair at the same time.
Thanks andje, I found some threads here about rewinding the turnigy, but I'm still a little confused. I've got to study the original stator and see how I can rewind it without changing the kv too much.
Yesterday I had an university test that went fine, so in the afternoon I decided to prepare the frame for the painting, instead of studying...![]()
recumpence wrote:You should have that bad boy powder-coated. It is far more durable.
Matt
Panasonic EEUFC1J471
Life Time @ Temperature:5000 hours @ 105°C
Height:20mm
Outside Diameter:16mm
Capacitor Case Style:Radial Leaded .Lead Spacing:7.5mm
Operating Temperature Range:-55°C to +105°C
AC Ripple Current:1765mA
Application:Low ESR
Impedance:0.059ohm
Impedance Frequency:100kHz
Impedance Temperature:20°C
Max Operating Temperature:105°C
Ripple Current Frequency:100kHz
panurge wrote:Good work with the motor windings....have you replaced also the bearings? damn, I've not your skills with wires and electronics, but if I was not so busy I would try to rewind my 80-100 too![]()
I will look for Reports on how the controller works in your setup.
OFF TOPIC:
I see you're from Berlin, what about to study engineering in Germany? Do you know if I can found courses in english?
thanks
panurge wrote:There's the beta CA-LRC option playing around these lines (works well, and better promises) to be used with both POT or hall Throttles as an Amp based or a speed based interface with RC ESCs, avoiding the use of a supplementary interface......and also if I understand that your build is low cost, and is a pleasure for you to play with electronics, let me say that The CA is a "must" for any EV rider-builder.
fattybarber wrote:I am learning all about e-bikes but have been riding for a long time and my only comment is you seem to have a long stretch from seat to handlebars and this may cause sore wrists as there will be quite a bit of weight on them, unless you are "very tall"
Just a thought.
Users browsing this forum: Google [Bot], speedmd and 11 guests
